20 Most Recent
Rosetta Stone Chinese Mandarin Level I & II Set Personal (chilspe) Questions & Answers
Loaded Start disc. When
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Headset Problem Rosetta Stone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Extract RSD files
Files that contain the .rsd file extension are normally associated with
the RealSQLDatabase. The RSD file format that associated with this file
type is a database file format that is used by the REALbasic software
application. The REALbasic software program is an application
that is used to develop other software applications that use the BASIC
programming language. These RSD files store the database information in a
structured format. The information contained in the database can then
be accessed using the various SQL commands. The .rsd file
extension is also used with Roland software program. These RSD files
store sound files that are used by the application. Or in simple terms you need the right software to use a RSD file.
