20 Most Recent
Rosewill 19" 12MS DVI R911E LCD Monitor Questions & Answers
MY MONITOR IS SHOWING AN INPUT NOT SUPPORTED
Does the monitor work on another computer? does the computer work with another monitor? I the answer is yes to both then here is the most likely solution
you may have the screen resolution and/or the refresh rate set too high on the emachines computer. For Windows XP: Boot the computer and use F8 to get the Safe Mode boot menu. Choose the first Safe Mode and log in,... if you see windows come up then go to display settings and and change the settings to something low like 800x600 and refresh rate of 60hz. Restart the system and you will the display and can make adjustments from there.
If either the monitor does not work on another computer or the computer does not work with another monitor,.. or if you are not able to see windows from in safe mode,.. you may have a more serious problem with the monitor or vid card.
Why my Pc monitor showing Input not supported?
There are several inputs that a monitor can handle depending if it's capable of doing so. For example, just like TV, if you want to watch a DVD, you have to change the input to Video and going back to TV, just choose TV input. The same way for computer monitors. If the monitor supports VGA, DVI, HDMI and others, you have to select the right input depending of the type of Video cable connected from your tower to the monitor. If you it is connected via VGA, choose VGA input. If the cable is HDMI, select HDMI. That will let your monitor switch from one input to the other..
Hope that works for you. -
I'll appreciate the feedback and the thumbs up.
Thanks.
-jash
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Hi receiving input not supported
This message shows that you are not setting the resolution correctly.
When you are in Windows, click on - Control panel - Display - Setting - Screen Resolution (set yo 1280 x 1024). then click ok.
Your floating box will gone.
I got the same problem and got the solution from
[email protected].
Hope this will help you.
Ringo
Hello
You could change your screen resolution on your computer......thats about all you can do.
7/25/2022 9:31:11 AM •
Rosewill...
Answered
on Jul 25, 2022
Laptop suddenly will not recognize my external hard drive
One thing to try is hooking it up to another computer. There is a possibility that the hard drive failed or the controller for the external storage device has failed. If it is recognized on another computer then I would look at the manufacturer's website for an updated driver
12/5/2017 2:09:41 PM •
Rosewill...
Answered
on Dec 05, 2017
Can i use my Rosewill LCD MONITOR as a tv
No. The monitor has no tuner in it and the scan frequencies used in TV's are different in monitors. Tuner modules will work on laptops and PC's with usb ports.
7/10/2016 10:12:40 PM •
Rosewill...
Answered
on Jul 10, 2016
Can i use a rosewill lcd monitor as a tv
That depends upon what you are using with it. Monitors do not have integrated tuners and thus cannot select channels. However, most cable providers use set-top boxes that perform the channel selection function for you. Many of these boxes have HDMI outputs that can be used with monitors that have these input capabilities. Otherwise, you need separate audio and video connectivity from the cable box to the set, either in the form of composite video plus audio cables, or a DVI cable with audio cables. Again, this is dependent upon what the cable box and monitor support.
7/10/2016 7:58:44 AM •
Rosewill...
Answered
on Jul 10, 2016
