20 Most Recent
Rosetta Stone V3 Spanish (Latin America) Level 1 Personal Edition (Win/Mac) for PC, Mac (1580228542) Questions & Answers
Error 2123 when i enter app
You may get this problem if you have BitDefender Internet Security. To fix it:
Open BitDefender, click Settings, set UI to Expert Mode. Click OK.
Select Antivirus, Advanced Settings then under Exclusions click [+] symbol, a browser opens, go to the following; C:\Program Files\Rosetta Stone\Rosetta Stone Version 3 and select the RosettaStoneVersion3 file, click OPEN. Then OK. Sorted.
Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Error 9119 rosseta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Error 9119 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure. Good luck and spread the word.
After selecting user nothing happens. Just a
Just got off the phone with rosetta stone support for this exact problem. This is caused by a failure during the language update (I'm going to assume just before this happened it was prompting you to update the language files to the latest version, that was my scenario).
In any event, the fix is simple - Browse through your file system to C:\ProgramData\Rosetta Stone\ (you may have to set to show hidden files to see this path). Open the Products.Xml file and scroll to the very end. There is going to be a "<Product>" node (note, not <ProductS>) as the last subnode of <Products> and this node will have a Course Id of "null". If so, delete the entire <Product> node down to </Product>. Save, close the file, and restart Rosetta Stone -- voila.
Rosetta stone error 9114
I'm using Windows 7 and was getting the 9114/9119 "minor error" when trying to install the language files. I copied my files to a flash drive, tried adding exceptions to my AV software (Microsoft Security Essentials), both to process and extension, no go. Then I tried setting the program to run in Compatibility Mode, and lo and behold it worked. Steps: right-click on the file, click Properties, then the Compatibility tab, and check the box to run in Compatibility Mode.Hope this works!
Rosetta stone doesn't detect mic on windows 7
Hey,I started to had problems with RS after I made some changes due to the error 2123, especifically, problems with the compatibility mode in RosettaStoneVersion3.exeSo. Go to Program Files-->Rosetta Stone folder-->RosettaStoneVersion3.exe. Right click on this file, Properties, Compatibility, and click on "Run this program with compatibility for Windows 7" (and check the box 'run this program as administrator').I use Windows 7 x32. After this, RS came back to life, and I was able to use my headset with it too.Hope it helps!
