20 Most Recent
Rosetta Stone Japanese Level 1 & 2 for PC, Mac Questions & Answers
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
How to configure keyboard in Rosetta
you can press SHIFT+ALT to change keyboard language
Also verify in control panel - regional and language options , languages tab, at details if is installed new languages for your keyboard
I have Japanese levels 1,2 and 3 for rosetta
The problem is related to the FNPLicensingService.exe service and FNInterface.dll file.
The first thing you can try is open Rosetta Stoneto and kill the FNPLicensingService.exe in task manager. This may or may not give you access to Rosetta Stone.
If that doesn't work, install Rosetta Stone on another computer (your license will allow two machines) then copy the rosetta stone directory from program files to the new system. Then open Rosetta Stone and it should be fine.
Before doing either of these things it's best to delete the c:\program data\rosetta stone\tracking.id file.
Most of my lessons are locked
If you have a cracked version, make sure your going INTO the file where the cracked application is and pasting THAT into the program file for RS (a window should come up asking if you want to copy and replace, keep both file or whatever if you've done it right.) Do NOT copy the FILE with the crack app in it to the program files this does NOTHING!!
Most of my japanese level one lessons wont
Usually this company wants you to spend money by asking you to go to their website to buy the Key to unlock the rest of your applications. I own the same program
Arigato!
Extract RSD files
Files that contain the .rsd file extension are normally associated with
the RealSQLDatabase. The RSD file format that associated with this file
type is a database file format that is used by the REALbasic software
application. The REALbasic software program is an application
that is used to develop other software applications that use the BASIC
programming language. These RSD files store the database information in a
structured format. The information contained in the database can then
be accessed using the various SQL commands. The .rsd file
extension is also used with Roland software program. These RSD files
store sound files that are used by the application. Or in simple terms you need the right software to use a RSD file.
