I have the above scanner and sample code that i wish to change. i know you use openwatson to compile for dos16 but can anybody tell me what i need to do to compile the source correct as i cant get my head round it.
You need Manufacture provided Software Devepment Kit. I cannot attach a file here so let me know if you still need this. You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
This sounds like a programming issue. What application are you using? If you are using a terminal emulation software then you will need to check your host for the issue. If you are using a batch program where the files are stored on the scanner then you will need to check your "validation" files to make sure the code you are scanning is in the scanner.
Normally I2of5 comes disabled as default in wavelink software.
You will need to enable it and if you are scanning barcodes of different legths, set both the maximum and minimum to 0 value. This will allow any length.
If you still have problems, get back in touch with me and send me a sample barcode as I have a verifier which will allow me to determine whether there may be a problem or not.
Hi there First I need to know if you got the software that is on existing pdt3100 on a computer? once I know the answer to this I can start to tell you how install software on pdt3100's
We hava a Symbol PDT 3100 barr reader. It worls properly picking up bar codes fron our inventoy, however we don´t know hoy to dowload them to a PC. ¿Is there a software or configuration to download the data to a PC? Thanks for your help Jos? jalal
