It looks like this mixer is no longer supported by B&D, however my unit only needs a NiCad battery pack. The pack that came with the mixer is made by Gates Energy Products, but I can't seem to find a replacement. Any suggestions would be appreciated.
If you have checked with B&D and the battery supply warehouses on line you could try this if you are good with a soldering iron and really want to keep the mixer going. In the past when I could not get a battery pack for a unit and didn't want to give up on it I have opened up the pack and replaced the batts with new units which are readily available from electronic supply sources such as MCM Electronics or Tritronics Inc. You just have to make sure you get the same size and capacity cells as well as the same type (ie NiCd, NiMH, etc) with solder tabs. Aother resource would be www.batteriesamerica.com. This has helped me get units going more than once. Good luck.
