It's not oil in the A200, it's #2 weight grease. Although when it gets old enough it can break down far enough to basically become oil (either that or someone put oil in it previously). There are a number of answers written on fixya.com explaining how to disassemble the transmission and change the grease. Fill with 36 ounces #2 grease. FYI : disassembling the transmission and changing the grease is a very messy task and one can VERY easily reassemble the transmission incorrectly, so consider bringing the mixer to Hobart to have the job done.
www.hobartservice.com Click on locate an office and enter your zip. The office will be glad to install one for you. I do not believe they will sell you one. They have to install it. But it doesn't hurt to ask.
Before doing anything else, make sure the hole in the whisk is perfectly clean by taking a cotton swab dipped in isopropyl alcohol and removing any remaining residue. It does not take very much residue to make fitting difficult.
If that does not work, the hole can carefully be enlarged using a round file or sandpaper wrapped around a pencil. Do this a little bit at a time and test fitting. You will want to do the minimum necessary to get the whisk to fit.
I just took a look at the www.hobartcorp.com web site and found a lot of parts lists. I did't find the AE200, but there were several listings for A200. You can ask Hobart if the A200 and the AE200 are the same on the inside.
As far as I know this is a food mixer. Concrete will definitely cause the overload to trip. Frequent triping has caused the overload to weaken and hence trip at lower values. You probably need to replace the overl;oad
