Isolate the hardware - do you have another computer that you can try that scanner?
Did you reinstall the drivers from the cd , if yes then you need to reinstall the latest drivers from the company .. use this link : http://software.canon-europe.com/products/0010534.asp
after reinstalling if you face the same problem please let me know...
Good luck...
Dear,
try to run its self test and do a test print and see the performance at that step.
what does it mean that u said , u have uninstalled the scanner. are you talking about power reset or the driver of that..
please explain it
regards,
dont rate it until it solves ur or helps alot
After a scannig is finished press Alt+Ctrl+delete and check whether any process related to the scanner is still running or not..If it runs do right click on the process and click end process...thne try scanning again
It may be a problem related to your Operating system and not with the Scanner. Please let me know more about the configuration and hardware present on your PC.
Hope after then I can provide you some ultimate solution.
Regards
Ellin
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Open the Windows Control Panel.
2. Open the Add / Remove Programs window.
3. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
Now download the latest version of the software for your OS from the manufacturer's website.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
Actually it is 2000 Professional.
Not sure what you want. It is a Dell Optiflex machine running Windows 2000 Professional SP 4 it has a HP 2100 printer, the Canon DR-2010C scanner and Seagate USB Drive attached to it what more do you need?
