I have had this dishwasher for about 4 months and it worked fine, untill I went on holiday for two weeks and found when i got back that the machine just kept filling and filling to overflow through the door and else were. I have checled all filters and other obvious bits. The program enages each time but just fills with no action from the rota arm or pump. Help anyone
My first question - If your dishwasher is still under warranty why you don't ask manufacturer service to take care for it !! Water supply to the diswasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water freely into the tub. Check if water are coming into the tub when the diswasher is off. If this is the situation- Open the valve (very easy to do it)and clean it from scale or other dirt (take care not to lose any part). Be aware you should disconnect the power cable from the machine before doing it !!!!! In most cases it should solve your problem, but if not - you should replace the valve with a new one. Good luck !!
'E6' OPEN CIRCUIT THERMOSTAT.
Technical / Advice Telephone. +44 118 933 6933
SPARES
TEL: 0118 933 6922
FAX: 0118 933 6942
UNITED KINGDOM
T: +44 (0) 118 9336 900
F: +44 (0) 118 9310 035
[email protected]
I do not have the parts list for this unit. You wil have to contact Baumatic to order parts.
To correct the E6 code you will have to have the thermostat replaced or wiring to the thermostat repaired that is causing the open circuit.
Thanks for choosing FixYa,
Kelly
