Saeco Classico Espresso Machine Logo
Jason Rezell Posted on Oct 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No Water Flow/No Water Draw
I haven't used my Saeco espresso classico in a couple of months. When I tried to prime the machine no water came out. There is no water being drawn into the intake tube. Additionally I opened the cover and did not see any cracks, holes or leaks in the intake tube. Finally I do get hot air out of the steamer. The only thing I can think of is that the pump is dead. Althought it looks and sounds like it is trying to work. Any suggestions? Also where do I go to get replacement parts or service for the machine? Thanks.
  • EspressoGary Nov 23, 2008
    Haven't used my Saeco Classico for about a year. Trying to prime it, the pump seems to run, but no water is being drawn up the tube.
  • StephenG58 Dec 17, 2008
    Water is being drawn into the sytem when the steam switch is on and the steamer valve is open. When the brew switch is on, no water comes out although the pump sounds as if it is functioning. The ready light of the brew switch randomly turns off and on. Occasionally I'll see a very small amount of water drip from the brewing head.
Cerini Coffee
Level 2:
Sergeant:
  • Saeco Expert 223 Answers
  • Posted on Nov 18, 2008
Cerini Coffee
Saeco Expert
Level 2:
Sergeant:
Answers
223
Questions
0
Helped
165740
Points
585
Sorry for not responding to you request, but I was not receiving any emails from Fixya.
You can contact me directly if you still need help with your espresso machine.
[email protected]
Authorized Saeco Service Center
www.CeriniCoffee.com
1helpful
My Saeco Classico has problem. The pump is working
It sound as though the boiler is blocked by scale. May also be the coffee filter that's blocked. I am not familiar with this machine, but assuming that it's just a manual espresso machine, try running it with the filter handle removed. Any water emerging? If so, the coffee filter cup and/or filter handle outlets may be blocked. If there is only a small flow the boiler is almost certainly blocked with scale and descaling may cure the problem (do the first run with the filter handle off the machine. Next run with it on)
2answers
Water does not heat
More then likely it's the boiler.
2answers
Ventilate shows.
try prime water on steam valve couple minuts if you have again message ventilate,that can be two reason,or your flow metar doesnt work or cpu board,but you try first prime water.
Connect Saeco Incanto Classico machine directly to water source
In our shop we come off the treated water supply with a water pressure regulator (adjusted to a very low pressure)and use a barbed fitting to connect to the hose inside the machine. You should be able to do something similar by removing the water tank seat on the body of the machibne and using the existing hole to connect your water. If you need something more specific contact [email protected]
2helpful
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
No flow of water
You can use any readily available tubing, but don't use sealants - they make their way into the water.
Prime it
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
V entilate?
the machine come with a little pump put water in the pump and insert the pump inthe water hole and press the water in the machine try to ventilate fill the water tank cheers
2answers
Water Too Hot, Coffee Too Watery
Sounds like there is something wrong with the machine. Could be the thermostats or maybe something like an internal leak that is causing the machine to overheat. It sounds to me like you need someone to take a look at it..
We service saeco espresso machine and are stationed out of New York..
If you need parts of cleaning supplies check out our website:
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
