I have repaired many D6, D6C Walkman and other walkman high-end, improve your performance if required and, if possible. My email: doctor.walkman @ gmail.com
Ho riparato molti D6, D6C, e altri walkman di alta gamma, aumentando le prestazioni, se richiesto e se possibile. La mia email: [email protected]
Your set is running wild because the motor has lost the regulation.Hence you will need to replace the motor. It is also possible that the belt had jumped and got into the large end of the pulley to make the capstan spin higher. So remove and check both of these sectiions and confirm. Hope this sorrt yourr fault.Good day
Get in touch with me and describe the problem. I have repaired many d6c and high-end Walkman and, when possible, increase the performance. doctor.walkman @ gmail.com
Contact me at my email doctor.walkman @ gmail.com, I'll ask you some questions and some photos of the WM-D6C in his possession. We will solve the problem
I'm an repairer of electronic and micromeccanaca I have repaired many walkman analog (WM-D6C, wm-dd9, etc.. Improve your performance if required and if possible) and many like dat walkman Sony TCD-D3. I just started to repair even for those who come out of Italy. If you would contact me to explain the problem better I'll try to help. Email: [email protected] Sono un riparatore di elettronica e micromeccanaca ho riparato analogico walkman molti (WM-D6C, WM-dd9, ecc. Migliorate le prestazioni, se richiesto e se possibile) e molti come dat walkman Sony TCD-D3. Ho appena iniziato a riparare anche per chi si trova fuori d'Italia. Se vuoi contattarmi per spiegare meglio il problema cercher? di aiutarti. Email: [email protected]
Because of the age of the unit, Sony will not carry that part. However, keep an eye on E-bay and yard sales and thrift stores and hopefully you can pick one up real cheap. Good Luck
