When i turn on the maker, nothing happens. The machine does not activate the water to heat and flow through the coffee.
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
I cannot get the on/off swtich to activate i.e. the unit will not turn on. It seems the as though the on/off rocker switch is just broken or there is some internal reset issue. No amount of "jiggling" will activate the unit, but if i leave it alone for some amount of time it will work-once than the process begins anew. This is not an issue a caffeine junkie needs at 6:00am.
my stainless steel coffee maker is making weak coffee
the on light is red and no water comes out, no warming up, no coffee comes out
