Intermittently get "print ramp up" error on Printek 8000se printer when printing. Unable to locate any information on this error message in any manuals.
SOURCE: printek 4300
You can buy a $3.00 micro switch from Radio Shack and replace the fault gap detector switch if you can solder electrical connections properly.
I've done dozens of them.
Steve
SOURCE: PRINTER WON'T PRINT WITH COMPATIBLE RIBBON
You need to go to setup and scroll to options menu, there you'll find :"Ribbon check" , turn it off and your good to go!
SOURCE: Paper Jam problem Printek 4300
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
