I think C4200 is your printer series rather than model number. You can however download drivers for all the printers in this series (C4205, C4270, C4272, C4280) from here:
nycdr:
I hope you are using original ink cartridges suggested by hp?
Try cleaning the print heads. There is a utility that will do that. look under properties for your printer, or see if it is a separate program given by http://www.hp.com to it support site and find out. It varies by model. You can also do it using some of the buttons on the printer. You need to check the support section of the manufacturer's site to identify the exact sequence.
try to use other browser if its not printing in windows explorer use firefox,then check print preview first...hit the dropdown on printer icon then check settings...update explorer if needed...thnx
If it is an HP printer, your inkjet nozzles may be failing. Replacement is the only answer. Look on-line for your make and model and buy generic substitutes for a better price. I would need to know the specific make and model # of the printer.
Hi Good day!! Try to do a printer maintenance Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
The print head is partially blocked, there should be a cleaning programme in your printer resources software. If that fails or you've already had a go, I'd suggest getting a print head cleaning kit (ebay).
It's worth having a look on youtube for solutions. Replacement print heads often cost so much that you can probably get a replacement printer for less.
Have you cleaned the printer using a Magicard cleaning kit? Your printer neds to be cleaned using a cleaning kit every time you cahnge dye film to maintain a top quality print. Cleaning kit contains 10 cards, 1 pen and 5 rollers - P/N M9005-761. You can buy it from your Magicard approved dealer or contact Magicard directly who will direct you to a dealer - [email protected] www.magicard.com
