Tumi luggage lock
SOURCE: change luggage key combination
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
SOURCE: TSA locked my luggage after searching and I dont
Hello; The only the thing I can say is take back to the airport make TSA open it or a profesional lock smith that will cost you. If the airport is not to far away Id carry it back to TSA
SOURCE: i accidently connected my hair
There is a small tube type 2.5 amp fuse that may have blown out...it is not to be used for anything else than a small charger like for a cell phone, pda, etc.
SOURCE: I just purchased a piece
Samsonite have a lifetime warranty, so taking the luggage into one of their stores will endeavour to replace it for you.
