Nintendo DS Console Logo
Anonymous Posted on Jan 04, 2009
Prompt says dogs need to rest. dogs have rested for four hours.
The dogs have been resting for four hours. when i try to wlak them, the prompt says they need to rest.
Anonymous
Level 2:
Scholar:
  • Expert 97 Answers
  • Posted on Jan 04, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
97
Questions
0
Helped
24031
Points
203
Nintendogs requires you to let the dogs rest for 24 hours before you can play with them again. It's a frustrating limitation that's designed to get you to play every day rather than getting tired of the game too quickly.
My dog needs 50mg of milk thistle (capsule) but all I could find was 175mg. How do I dose that?
open the capsule and pour the contents onto a plate
place it in a line and divide the line evenly into 3 portions
each portion will be 58 mg which will be ok as dosage is on dogs weight add the powder to the food save the rest till next dosage time and divide the rest in 1/2 and feed 1 portion ,leaving the last portion for the next dosage time
Correction. How do you install the bobbin case for the Singer XL 420 sewing machine
Please refer to pages 102 to 104 of your service manual. You will have to remove the two screws in the plate covering the feed dogs to insert the case, and identify the top of the case, which is the flat part. There is a part that sticks out and it should be on the right towards the bottom. That part must rest against a small silver spring to prevent the case from rotating in the bobbin basket while sewing. It is easier if the bobbin case is inserted slightly clockwise, then rotated into position. It is illustrated on those pages.
On the Futura XL models, it is easy to insert the case so that it is just sightly lopsided, so visually inspect it to make sure that all four sides rest evenly in the basket.
It is also essential that you FREQUENTLY clean both the top and bottom areas, as illustrated on those pages, about once every 5 hours of sewing, or if you're experiencing problems. You also might want to put ONE drop of ONLY sewing machine oil in the center of the basket at the same time.
HOW MAN HOURS BREAK IN CALIFORNIA AFTER 8 HOUR SHIFT?
Employees must, with two exceptions, receive at least eight hours free from work between shifts, whether they are "split shifts," "on call shifts," "back-to-back" shifts or ordinary daily shifts.
Rest between shifts is not required if:
  • the total time worked during both shifts does not exceed 13 hours; or
  • the employer and employee agree in writing to reduce or forego the eight-hour rest period.
Example
Monica works in a restaurant. She is on split shifts, working from 11:30 am to 2:30 pm and then from 4:00 pm to 7:00 pm. The total time of her two shifts is 6 hours. Monica does not need to have eight hours off between the shifts because her total hours worked on the shifts do not exceed 13 hours.
Note: The requirement for rest between shifts operates simultaneously with the requirement for daily rest; an employee's schedule must satisfy both requirements. For example, an employee might agree in writing to work two eight-hour shifts in a row without any time free from work between them (the employee's agreement means there is no violation of the rest between shifts rule), but if that results in the employee receiving less than 11 consecutive hours off in a day, the employer will be in violation of the daily rest rule* and therefore it is not permitted.
* Unlike the case with the rest between shifts requirement, an employee cannot agree to waive the daily rest requirement.
What is wrong with my dog
Other than being old, it seems as though she is sick. Can you take her to a vet? Let me know. Best to you & your dog.
What is the safety limit in decibels before hearing is damaged by loud music?
85 decibels is the generally accepted limit for 8 hours of exposure per day (you have to give your ears time to rest in between).
At 91 decibels you have about 2 hours before suffering damage.
At 100 decibels, it's about 15 minutes of safe time, and immediate damage (no safe duration) can occur at around 140 decibels (about as loud as a jet engine or firecracker).
The important thing to note about volume and ear safety is that you have to rest your ears (i.e. nothing too much louder than a conversation) for the rest of the day to avoid risking damage. That means that after 2 hours at 91 decibels, you need to rest your ears for 22 hours before these guidelines can apply again.
Many bands play shows at around 100 decibels, so invest in some HearOs or other decent protection.
Maybe your dog get so stomach pain.
I have a puncture on my therm-a rest matt and need an addresss
The information regarding the maufacturer and address information you need about your matt is :
E-mail: Cascade Designs, Inc.
Tel: 1-206-505-9500
Fax: 1-206-682-4184
Address:
4000 1st Avenue South
Seattle, WA 98134 U.S.A.
Hours of operation:
Monday–Friday, 8:30 a.m.–4:30 p.m. Pacific Standard Time.
Hope this helps
1helpful
2answers
Agitator Dogs
To disassemble, you need to destroy the tabs that are holding the translucent thing to the four post on top of the bottom part. This of course means that the translucent thing needs to be replaced too. I hammered the screwdriver into the tabs until they gave way. The rest of teh parts come out undamaged.
(if you have snips with really long handles, that would be a better tool).
1helpful
2answers
Massaging neck rest question
The massaging neck rests usually offers you two relaxation therapies: variable speed vibration massage to customize massage intensity and heat. Some of this devices even have a "comforting sounds" option (which makes relaxing sounds). Besides that most of the massaging neck rests offers the same featurs. They wrap comfortably around your neck and shoulders, supporting your head in a comfortable position (Usually - memory-foam filling and a soft fabric cover). Hand-held control adjusts the vibrations to your specific comfort level, without having to stop the massage. Includes plug-in AC adapter, or you can use four AA batteries
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
