Hardware & Accessories Logo
Anonymous Posted on Nov 05, 2012
Optimax he plus 31c timer - Hardware & Accessories
Gene Haynes
Level 3:
  • Hardware & A... Master 5,391 Answers
  • Posted on Nov 07, 2012
Gene Haynes
Level 3:
Answers
5391
Questions
0
Helped
2606567
Points
14124
2answers
Ferroli optimax he plus 31c boiler timer instructions
Why does the display appear and i can set timer but then display goes blank and i carnt getthe lcd screen to display anything at all??
1helpful
Ferroli optimax he 31c. brand new system will only heat 3 of 8 rads. boiler on 90c will only burn for 15sec then D2 shows and it cuts out. Why??
it is either your pump is not running or blocked [ debris from installation ect ] or your diverter valve is stuck partially open allowing a little water to pass into the heating system [ usually first rads on system ] it runs for a short while and cuts out because your overheat stat is kicking in because of poor circulation [ it is only running around the primarys in the boiler where it quickly reaches the over heat limit ] temp tends to rise approx 1 deg per second a clear indication of circulation problems.
solution GET RID OF THE FERROLI
1helpful
Do you know where I could get the instructions for setting the clock timer on my optimax he 31c
I sent an e-mail to [email protected] telling them that my Optimax HE 31 C
manual didn't include instructions for the timer, and received a manual via e-mail within minutes.
You probably won't get a reply during the weekend though.
Trevor
2helpful
2answers
Hi i have a ferroli optimax 31c , hot water works but my heating dont ,it comes on the the heat temp raises to its highiest then cuts of saying A3 AND D2 can you help please
hi had same problem engineer came out and the diverter valve was cloged up sorted it and recomended a system flush plus install a magnet clean whitch picks up debri be 4 it gets 2 the boiler.
7helpful
Ferroli optimax he 31c diverter valve noisy, does anyone have details of how to remove and strip to se if some debris is making it stick slightly and be noisy. Any help would be very much appreciated,...
there is just two screws holding divertor valve in remove these screws (do not touch painted screwheads) then twist left to right and pry gently were the two screws were fitted. best bet is to replace diverter valve head to stop noise
5helpful
I have just tried to run my ferroli optimax 31c boiler. The boiler fires up, but then displays a d2 message and the radiators do not heat up. Any ideas what causes this problem and how I can solve it...
D2 is not a fault what that means is delay and 2 refers to CH which means the boiler has gone into standby mode. you need to check that your CH circut is open, there is a filter on the return valve into boiler make sure this is not blocked. If this is blocked the water is just going though the boiler by-pass so then the boiler thinks its up to temp. hope this helps
21helpful
7answers
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
