Only mail that can't be delivered, will bounce back. Check if the address is correct, and read the mail that is coming back, to see what the "mail master" did tell about the mail and the reason it is bounced.
I can help you troubleshoot over the phone and then fix whatever unit in the jukebox is causing the problem. Please email [email protected] and I'll email back my phone number.
I am affraid, that this is only configurable on mailserver. You can redirect emails from those blocked users to trash, but there is no possibility to send back bounced msg like "account doesn't exist".
all 47uf, all 220 uf, all 100uf, probably most if not all of the 10uf, and 4.7 uf. it is a pain. they are all surface mount caps and very close to feed thru's. I repair these for a living and have specialized de-soldering equipment just for these. since you have it apart why not check out www.tv-techs.com. it might be easier.
It sounds like your tuner mode has been changed. To change this back to cable hit menu arrow down to install, then arrow down to tuner mode and change that to cable. That should take care of your problem, if not email me at [email protected].
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
