Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
Posted on Jan 10, 2009
Clogged vortex holes
I own a Dyson asthma and allergy machine. Works okay, but definitely not as well as when I first got it. I have cleaned my filter on a regular basis which helps slightly with suction. As I was cleaning my machine today from top to bottom in an effort to figure out the problem, I noticed there are six holes in the top of the cylcone chamber of which 4 were plugged with what seems to be balls of hair! I have tried everything from rinsing with water to unscrewing the machine in an effort to get this **** out. The screws are apparently for looks or just to throw you frustration level into high gear. Is there anyway to get into this chamber and clean my machine for good?
  • Anonymous Feb 10, 2009
    I have the same problem.
    Everything else is clear (i.e., hoses, etc.) but cyclone is plugged.
    I basically I have no suction at beater bar due to this.
    I personally think this machine is a waste of money and difficult to work on (and yes - I've had to work on this $500 piece of plastic in it's short life thus far).
  • Paula 47 Feb 13, 2009
    I have Clogged vortex holes on my DC17 anybody has a resolution how to Fix it???
    Tank you.
    Walter
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Feb 15, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
31532
Points
24
I had these same issues. It came down to my husband beating the **** out of it several times. He'd take the canister apart, pound it on the ground, use a hair dryer to blow out as much as we could, a hanger down the top to pull out any hair we could grab. Then I'd use it -- it definitely loosened up some stuff. He'd pounded on it again and more stuff came loose. Don't know if it's fixed, but it's got it's suction back. Now I have have hose suction issues.
It felt good to beat on it a bit.....
  • Anonymous Apr 03, 2009
    Broke down and took it in for repair. Service folks aren't even supposed to take the vortex assembly apart. They told me it was a known defect and warranty issue. Of course mine is out of warranty but it only cost me $75 to get a whole new vortex and canister part.
    Check out http://www.aaavacs.com/. He's very knowledgeable on Dyson's and may be able to help.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
699
Points
5
I had similar problem and have just posted a solution on another question. Check the hotlink under my user name or search under dyson hair filter (the problems with the hair inside the vortext eventually lead the filter to keep getting clogged.
mahealani100
DC18 Allergy - can the clear bottom filter be removed
Hi Angela, it's Jack at Dyson.
DC18 Allergy is equipped with a HEPA filter engineered to last the lifetime of the machine in normal use. As long as it hasn't been damaged in any way, we wouldn't expect it to need replacing - and for this reason, it isn't designed to be removed from the main body of the machine by the user.
I hope this helps, but if you'd like any further guidance or advice you're welcome to contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US) or 1-877-397-6622 (CA).
tip
Dyson DC08/08T/19/19T2/20/21/29 - Washing the filter
To wash the pre-motor filter in your Dyson DC08/08T/19/19T2/20/21/29, please follow the simple steps shown in the video below. This procedure applies to the following Dyson variants:<br /><br />DC08 - Origin, Animal, Allergy, Carpetpro, HEPA, Base, Toolkit, DC08i, Standard.<br />DC08T - Origin, Allergy, Carpetpro, Complete, Animal. <br />DC19 - Toolkit, Allergy, Comet Exclusive, Plus Tools, Precision. <br />DC19T2 - Multi Floor, DC19T2i, Animal. <br />DC20 - Origin, Allergy, Animal, Stowaway Blitz It. <br />DC21 - Stowaway Motorhead.<br />DC29 - Exclusive, Allergy Parquet, Allergy Parquet Plus, Origin, All Floors, Allergy, Allergy Complete, Animalpro, Origin Plus.<br /><br />The filter should be washed every 3-6 months using cold water. Always ensure the filter is totally dry before refitting it - this may take up to 24 hours.<br /><br />For further help and advice please visit <a href="http://www.dyson.com/">www.dyson.com</a> and click on Support. <br /><br />Dyson Customer Service<br /><br /><utube src="TIsdhNkiIQs&feature=relmfu"><br />
on Jun 22, 2011 • Vacuums
tip
Dyson DC08/08T/19/19T/20/21/29 - Washing the filter
DC21 - Motorhead.
For further help and advice please visit www.dyson.com and click on Support.
How do I remove the hose from my dyson dc17
You may download the user manual for your Dyson DC17 Asthma & Allergy model from the link below;
http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
If you found my answer helpful, please be sure to click the 4 thumbs up icons in the top right hand corner of my answer. .
3helpful
Where do I get a copy of the manual for the DC17
Greetings from GoVacuum,
Thank you so much, if you have any other questions about your Dyson feel free to send me an email, [email protected]
Chris Jones
GoVacuum.com
2answers
Hi my dyson dc07 allergy is not picking up the dirt from the floor or carpet . I have cleaned it's filters emptied it's dust but nothing works
Hi its Darran at Dyson.
The first thing to check is that the brush bar is rotating when the machine is switched on and lowered into the vacuuming position. If it isn't, make sure the brush control dial is in the centre position and moves forward to the on position when the head is released.
Its worth checking the whole machine for blockages as outlined in the user guide or on our website support section at www.dyson.com.
Should you need any further assistance, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
3helpful
4answers
Dyson DC 17 Asthma allergy Vacuum
I had a similar issue. I called Dyson. Hey why not, the number is right on the from of the machine. SO IS the beater bar on/off button, right next to the big red on/off switch. It does have a safety off when something jams the bar from rotating so the motor doesn't burn out. I also removed my sock and on restarting the thing, the beater bar would motor was not turning on. I thought the reset would be inside but no, it is right outside in plain view, which I didn't see either. It is a grey button opposite the big red on/off switch. Boy did I feel dumb after that phone call!
Installation of a Dyson filter
Hi Nancy.
Thre are 2 filters on the DC4.
The first is A one piece filter which colud just be circular pad or purple plastic hepa filter this filter fits directly on top of motor.
To fit this remove the wastebin & vortex head from machine now look down on top of machine you will see A circular cover with fins on it remove this & this type filter goes in there.
The second filter will be yellow plastic frame which has circular foam insert inside it the foam is normally blue & can be pulled out so you can wash it.
This filter fits directly on top of vortex unit, To fit this filter push button near handle on the top of wastebin & vortex the lid of vortex will open you wil see A ring of holes the filter goes in here shut the lid & thats it done.
http://dysonmanuals.llc.nu/
7helpful
3answers
My dyson smells bad
Hi.
Yes you can use lots of soapy water & pressure washer or hose to clean the vortex unit but remember it will take at least 36 hrs to dry out internally.
1helpful
3answers
Washable filter is getting clogged with dog hair
I have a Dyson Animal Absolute and a rescue white american eskimo dog and two tabby cats.
We found white hair on top of the washable filter and called Dyson to fix it. There shouldn't be anything on that filter.
The Dyson rep said:
Check the black rubber seal that surrounds the "cyclone" holes as it may need to be pushed down because it isn't sealing properly.
To do this remove the cannister and dump out the stuff in there. Do it outside so the fluff doesn't circulate in the house.
Turn the entire filter part upside down so you can see inside.
Check the seal that is at the bottom of the entire filter part and look at the two half moon "nozzles" that **** up the dirt.. now make sure the black rubber band that surrounds those two nozzles is either up or down... do this then vacuum a bit.. check the washable filter to see if it is clean...make sure the rubber seal actually is sealing.. it should just set into place once you have it done properly.
Now if this doesn't fix it, call Dyson, the number is printed on the front of the machine.. and give them your serial number which is located behind the removable cannister. The machine has a 5 year warranty.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
