Need the Blower tube assembly
SOURCE: Homelite leafa Blower Model 08010B
They also provided the address of this parts supplier:
Gardner
Email Address:
[email protected]
Address:
3641 Interchange Road
Columbis OH 42302
614-456-4000
SOURCE: need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
SOURCE: Homelite ht-17 magneto
Go to Gardnerinc.com and click on consumer. Then click on partsmartweb. On the left side of this page change your selection from Kohler to Homelite Consumer Products and enter your model number. You have it as HT 17. This brings up a lot of different equipment so I would enter just part of the serial number or the ut number. This is located on the body of the trimmer on a silver tag.
This will take you to the parts illustration and parts list for your trimmer.
SOURCE: homelite gas leaf blower losing power
There might be a small screen in the exhaust (it's a spark arrestor) that gets plugged with carbon. Will cause loss of power and eventually the machine will not run. You can just take the screen out and it will run better. Check the exhaust ports (look into the cylinder area after you take off the muffler) and see if it/they are plugged. If so, use only plastic or wooden items to clear the carbon out. Be careful not to get any in the cylinder. If you do, pull the starter rope several times to blow out the carbon.
Otherwise, some fuel line cleaner would be a good try to assist in the problem.
SOURCE: Need to replace primer bulb( rubber cracked) can't
go to pats small engine parts yuo should be able to find it there good luck!
