KICHLER TRANSFORMERS - PROFESSIONAL SERIES - 15PR300-SS - Stainless Steel Logo
joewhite Posted on Jan 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
15PL300 kichler transformer trouble shoot manual
The internal plug has no power
Gene Haynes
Level 3:
  • Kichler Master 5,391 Answers
  • Posted on Jan 06, 2013
Gene Haynes
Kichler Master
Level 3:
Answers
5391
Questions
0
Helped
2603883
Points
14124
1) Product warranty policy
http://waterheatertimer.org/pdf/Kichler-Landscape-Lighting-warranty.pdf
2) Basic instruction manual:
http://waterheatertimer.org/pdf/Kichler-transformer-instruction-sheet.pdf
3) Contact Kichler:
[email protected]
866-558-5760
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1 Related Answer
A
Anonymous
  • Posted on Jun 09, 2011
SOURCE: I have a kichler 15pl300 where it does not
I have been unable to locate manual for Kitchler low voltage products.
The troubleshoot page says check on-off switch, and put black tape over photoeye for two minutes, but does not elaborate on what to do.
1) Kitchler e-mail and contact information:
[email protected]
Mailing Address
Kichler® Lighting
7711 East Pleasant Valley Road
P.O. Box 318010
Cleveland, Ohio 44131-8010
U.S.A.
2) Kitchler troubleshooting page has nothing:
http://www.landscapelighting.com//portal/faqs_page/portlet_landscape_faqs/cms/begin?portlet_landscape_faqsresource=/OpenCMS/sites/landscape.com/faqs/Faqs_Main_Page
Add a comment and say what you discover for others with Kitchler problems.
Open following link for Intermatic/Malibu troubleshoot:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
The timer on my 8100-0600-01 Malibu light transform is not working the on and test part work but I want to set the time on
The electronic dawn dust timers can fail easily in power surge etc.
Manuals, tips and troubleshoot resources on following link:
I recommend professional grade transformer for anybody wanting better quality and resistance to problems:
http://waterheatertimer.org/Kichler-transformers-and-manuals.html
How do i set the Kichler 15E120BK landscape timer?
http://waterheatertimer.org/Kichler-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
Depends on which timer.
Some Kichler have analog timer built in.
Most Kichler timers are made to run constantly... with option to plug your own timer into the outlet located on front of Kichler, or to plug in a kichler-model photoeye.
Gene
Just need help wiring up a transformer. 15PR200 SS
1) Copy following link for available resources for Kichler 15PR200 pro-series 200 watt transformer with selectable voltage output:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
2) Add comment and describe how many watts, and what gauge wire you are connecting to transformer.
Need schematic drawing of Kitchler 15E120BK
1) Kitchler 15E120BK has same operating manual as Paradise GL22730:
http://waterheatertimer.org/pdf/Paradise-GL22730BK-transformer.pdf
2) There is no internal schematic drawing or CAD drawings that I can locate online.
How to wire
Following manual has different wiring diagrams:
http://waterheatertimer.org/pdf/Kitchler-transformer-wiring.pdf
Kitcher wiring with boost transformer: 120Volt
Black hot from breaker connects to Black Line wire
White neutral from breaker box connects to wht (COM) wire
Output to light is shown.
http://waterheatertimer.org/images/Kitchler-wiring-1-1000.jpg
Kitchler wiring with block terminals. 120Volt
Bare ground wire connects to GRD terminal
Black hot from breaker connects to 120VAC PRI terminal
White neutral from breaker box connects to COM PRI terminal
Output to lights is shown.
http://waterheatertimer.org/images/Kitchler-wiring-2a-1000.jpg
Additional resource:
I have a kichler 15pl300 where it does not transform from 120 Volts coming and it does not want to send out 12 V on the other side. The 120 volts has confirmed for be live.
[email protected]
Mailing Address
Kichler® Lighting
P.O. Box 318010
U.S.A.
KICHLER 15PR600SS
Here is a link to the specs for that trnsformer. It looks like there is only the switches for each circuit. Dumb question Are the load switches turned on?
http://www.landscapelighting.com/opencms/opencms/system/galleries/pdf/ll_spec_sheet/landscape/15PR600.pdf
This is all the info I could find on it for you. I hope this will help.
Top Kichler Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
