I need the handle
You should perform a Google search or use one of the resources indicated below:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
SOURCE: Defective hedge trimmer with a lifetime warranty. How do I file
Contact Us, Warranty and FAQs
We want to hear from you! We are always looking for the best way to
stay in touch with you. If you cannot find what you're looking for, feel
free to call us toll free at the number below. Our customer service
specialists are available Monday – Friday 8 a.m. to 5 p.m. CST,
excluding national holidays.
1.866.348.5661
WARRANTY CLAIMSTo request a
warranty replacement, please either:
For Garden Products:
Fiskars Brands, Inc.
Atttn: WARRANTY DEPT
780 Carolina Street
Sauk City, WI 53583
USA
Hope this helps.
SOURCE: I have a McCulloch virginia mh 542 p hedge
turn on, full choke, primer X5, pull cord.
if it don't start try cleaning spark plug and air filter, then try again.
