I just purchased the Koss CS95 Headphones. They came without installation instructions. How do you connect them to the PC so they work with speech recognition software?
SOURCE: Koss KS3102 - Audio Problems
I think I have had the same problem. It seems like the system resets itself randomly. I think if you first turn it on in AV-1 or AV-2 mode, then hit the menu button on the remote, then scroll to ihe 'input'option, hit that then pick 'digital'. Do this for both AV-1&2. UI hope this fixes your problem!
SOURCE: Need Infrared Remote Code...
I had the same problem and it took an act of Congress to solve it. However, I can tell you that through much more hard work and time than it should have taken I discovered the infrared code for my "One-For-All" remote model URC-4021B00 is--0651. Not sure if it's the same for any other remote control models, but give it a shot.
SOURCE: Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
SOURCE: one for all remote urc-3220 to koss dvd player ks-4110
i need the code to program my koss player on the one for all replacement urc 4220 remote
SOURCE: KS3102 Digital Optical Input Problem
What I did was turn on the system, don't put in any dvd in, or select an output 1 or 2. Press Menu on the remote, the display on the system display, not on tv should show Speaker, and other options. Select Input, select the one you want to use as the Optical Sound by press enter, then it will ask you on the system display input or optical sound input. Select optical input and press enter it will then say saved. You can then hit exit til goes back to where the display is back on main screen, or just wait til it exit by itself.
