I have picked this up second hand and cant seem to get anything to work other than 'standard coffee'. This all appears to be a problem relating to the milk compartment (namely the pump maybe) not working properly. The machine knows the milk container is present, but when I press hot milk, capp etc. it thinks for a second then goes back to the main screen.
SOURCE: milk container won't fit onto front of machine
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
SOURCE: I have a DeLonghi Prima
Maybe youare not pushing the milk-container sufficiently in. Mine has been increasinglyhard to fit. After speaking with DeLonghi service, they suggested lubricatingthe o-rings on the nozzles on the machine. I asked if cooking oil would be ok,to which they agreed. To I took a cottonstick and dipped it in ordinary cookingoil, and swept it over the inside of the two nozzles on the milk-container,since the o-rings on the machine itself were hard to get to. Now it workssmoothly. I was reluctant to try that out before speaking with DeLonghiservice, since they are so set on only using original stuff for the machine,and I did not think a machine this expensive would need this type of 'help'. Useat your own risk :-)
Flemming.
SOURCE: help received the Delonghi Cafe
http://www.manualnguide.com/dl/10372/
Go to the above link and download the manual for the BCO 120T
It should provide the basics to get you going
Making a good espresso with steamed milk takes practice
If you don't have the frothing pitchers.. buy a couple in different sizes
Used cold low fat or non fat milk..
It takes practice to get good at it.. a hand on the side of the pitcher to make sure you don't scald the milk.. etc.. you don't want the milk to bubble/boil..
If you have a control valve for the steam pipe.. immerse the pipe about an 1/2 inch or so into the cold milk and slowly open the valve.. until you have it open full. Jostle the pitcher to move the milk around pretty much during most of the process once it begins to warm and foam.. raise the pitcher to heat the milk in the bottom .. then lower it as the foam begins to form...never letting the steam pipe out into the froth. Once done..wipe the pipe clean with a wet cloth.
Grind of the coffee is imporant as well as the roast and when you fill the portafilter don't over tamp.. If you pack it to tightly.. won't brew... too loosely.. brews too fast.. You want to see the coffee shots come out and form what's known as crema... which is a thin layer of tan or light brown foam on top of the shot. If aren't getting this..the coffee is either ground wrong or packed too tight.
It's an art..and nothing beats practice.. there are scores of books and internet threads on how to froth milk and make different coffee drinks..
I love a good Cafe Borgia now and again.. we live in the Portland, Oregon area.. everyone here is addicted to the bean..
Best of Luck
Have you ever wondered, 'how do I descale my
expresso machine?' First lets us understand what is exactly is scaling.
The build up of minerals inside the hot parts of your coffee machine or
espresso machine is commonly called lime scale. When lime scale
builds up inside the Espresso machine, it slows down the water flow,
reduces the boiler capacity and can prevent your coffee machine from
working properly. To keep your Espresso machine operational at full
order, it is important to descale it every three months. The time
intervals between descaling depend upon many factors. Quality of your
water and the amount of water running through the machine are the two
main factors that decide the frequency at which you should descale your
Espresso machine. The more you your machine, more often should you
descale it. In some cities, in conjunction with a water filter you can
use your coffee machine for a year or more without descaling at all. If
you use less water by drinking espressos you'll need to descale less
often than if you make cappuccinos.
Descaling products are widely available from stores
that sell coffeemakers and espresso machines. Be sure that the product
you buy to descale your Espresso machine is intended for this specific
use only. Before you descale your Espresso machine, always unplug it and
make sure that it is cold. Also, never immerse the appliance in water
and nor should you use abrasive cleaning products
or scouring materials on any part of your Expresso machine. In case
your Espresso machine does not come with a instruction guide or booklet,
then use a proper citric acid based descaling solution designed for
espresso machines. This should be mixed and prepared as per the
instructions on the bottle or packet. Once your Espresso machine has
been descaled properly you would not be left wondering, 'how do I
descale my expresso machine?', treat yourself to a great cup of coffee.
Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
