My Horizon fitness T207 (TM254) treadmill is continually beeping when switching on and I'm unable to start the motor, I've checked all cabling etc which is secure, the left display shows 502, the top one shows 207 and the right one shows 0.
SOURCE: lost lubing instructions for treadmill and tool ex wife took them
Horizon fitness sells silcone gel lubricant or many stores also carry it.
Gerritt
Serving the Twin Cities
SOURCE: Erratic speed on Horizon treadmill.
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
SOURCE: i have a horizon t92 treadmill. my problem is with
Loosen rear tension and recent and tighten.
First grab the walking belt on an edge and lift up, It should only lift up 3 inches, this about the right tension
There are two guides underneath near the front make sure the belt is underneath them. (they touch the white side)
If OKay, remove the endcap byu the tension control bolts (two screws underneath) and make sure you have adjustment room (threads showing on bolts toward the rear)
these bolts should look about the same position with respect to the roller.
Run the machine on slow, walk on it and try to stop the walking belt, if it slips - turn both rear bolts 1 turn clockwise.,repeat until it doesn't slip
Get off and run the machine on slow 2mph, turn the bolt on the side the belt wanders to 1/4 turn clockwise. If it goes over fast you may need turn the bolt 1 full turn right away (it shouldn't). If its kinda of stable - speed up machine to 5-6 and repeat.
Note the front of the belt should be centered first, this is preset and usually doesn't need adjustment
SOURCE: WE have just moved home and lost our safety magnet
here's a link to an ebay page of treadmill safety keys for horizon treadmills. hope this helps!
SOURCE: I have a Horizon elite 507 treadmill, everything
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem.
Methods to test a motor:
1)
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
2)
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
Testimonial: "Many thanks for prompt response, seems that the treadmill works only when in the upright position and not the horizontal as per normal. Gonna have to learn to run up walls i guess"
