Car Audio & Video Logo
Posted on Jan 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cut out I just got a kicker zx400.1 and kicker comp 12s every time i turn the radio up between 23 and 27 the amp shuts down and then it comes back on but it keeps doing it till i turn it down ..... so what does that mean
Larry Tezekjian
Level 2:
Scholar:
  • Expert 117 Answers
  • Posted on Jan 28, 2009
Larry Tezekjian
Expert
Level 2:
Scholar:
Answers
117
Questions
0
Helped
49066
Points
172
Do you have ONE pair of 12's? Are they single voice coils? Dual? Bottom line, you are either over driving the amp (bass controll up high on the head unit (stereo), or the "load" on the amo is too low, meaning 2-12'" dual voice coils parreleled would give you a 1ohm load. Need more info, need to know what the bass is set on on your stereo, what size power wire to the amp, and I can wrap up the solution. ok?
Take care,
Larry T
Winona Lake, IN
I have the xterminator 2000d amp and I am wanting to wire two 12s and one 15 to the one amp. Both Kicker speakers are 4 Ohm SVC. Am I able to do this safely?
Wire the two kickers in Parallel, this will half the resistance of 8 ohms to 4 ohms and match the 15" speaker on the other channel.
2answers
I have 2 12s kicker comps 2ohm. One of them are working fine, the other one, when I hook up to amp, it throws them both off and just does this repetitive bass....or when I just hook the one thats...
Measure the resistance across the voice terminal of the known good sub, and then compare that to that of the problem sub. You may see a greatly changed value, which likely means the voice coil is damaged. Don't connect the subwoofer again because you risk damaging your amp as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
I need to know what to put the frequency at for my subs... they are 2 12" kicker comp's
40 - 45 Htz is the usuall. It really depends on the music you listen to. They are built to handle a little more mid bass. Where they are located, power supplied, direction the subwoofer is facing will all have an effect on what you need to set it at. My suggestion is follow the basic steps in setting up your amp. 1. turn your amp gain all the way down. 2. turn your radio volume to 75% of max. 3. start turning up the gain until you obtain the sound you want. You want to do this so your don't "clip" the sub. Kicker is good, but the comps can only handle so much before they start popping. This will heat up the voice coils quickly and cause them to fail prematurely. Hope this helps.
Kicker zx1000.1 stopped working completely. I have 3 Kicker 10" cv subs hooked to it. The first time it shut off I turned the system off. When I turned it back on it worked for a few minutes and...
First check to see if your'e getting power to the amp by using a test light and touch the main power(12V battery) connector on the amp, test light should come on since it's constant 12v supply. Now turn on the radio and test the remote wire connector on the amp and you should have 12V(test light should come on). Also make sure that you have a good connection with your ground wire, check both connection points to make sure it's good. Now if you have power where your'e suppose to and when your'e suppose to and the amp does not power up, then it may be time for a new amp. Try wiggling the connections at the amp a bit, the solder may be cold/loose.
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
2answers
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
Capacitor shuts off
HI DUDE UR CAR BAT NEED TO B CHANGE PLUS UR ALTERNATOR IS GOING TO FAIL SOON ... THATS ALL ... IF U ARE USING NOW IT MAYBE COZ LOTS OF PROBLEM TO CAPICATOR
2answers
Power from the kenwood 9103D to the Kicker comp 15's is on n off
Most times I hear of people turning up the volume on a head unit and cutting off on the amp it tends to be wired to a speaker with the wrong impedance. I googled kicker comp and got tons of different models, not to mention almost all of them were 250 watt rms. That amp is 900 watt RMS at 2 ohms. If you only have 1 woofer, you can't possibly wire it wrong being all the subs I've seen in the results were 4 ohm. If you are using just one though, you should get a larger speaker, both 2 ohms and 1000 watt rms to prevent distortion. I'm afraid I can't answer your post without further information on the sub you are using.
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Kicker amp shutting off
hello my friend you should have the input signal set to 500 miliamps do not go over, another thing is that if you have good ground and the battery is good and it has the sufficient amps to push it.also the ohms of your spkrs are not too low,you need to check all that.
good luck
[email protected]
Top Kicker Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
