I have a Slant Fin Cool Mist GF-220 humidifier and I'm trying to figure out where you fill the tanks with water. Thanks for your help.
FILLING THE WATER TANKS
1. Before filling the water tanks, push the POWER switch to the “OFF” position and
unplug unit. Refer to cleaning instructions.
2. Remove water tanks from base, turn each tank upside down and remove tank cap
by turning counterclockwise. Fill tank with clean cold tap water.
Replace the tank cap by turning clockwise. Tighten firmly.
3. Carefully pick up tank, since it will be heavy when full, and slippery if wet.
4. Place water tanks on base. Make sure tanks are properly placed, otherwise, the
humidifier will not work correctly.
I removed both tanks filled one with water put *** back on base and everythingnspilled out
Quick reply. Thanks a lot.
