Symbol MC70 Logo
Posted on Feb 18, 2009
Im using DataWedge v1.0 for scanning the barcode in Motorola MC55.How can i get scanned data from DataWedge to my application.i.e where DataWedge will store the scanned information.Thanks.
  • Anonymous Feb 26, 2009
    Is there any other way to read barcode without using DataWedge in Motorola MC55.Thanks
  • mcsasitharan Feb 26, 2009
    Is there any way to read barcode without using DataWedge in motorola mc55.Thanks
Anonymous
Level 1:
  • Contributor 12 Answers
  • Posted on May 14, 2009
Anonymous
Contributor
Level 1:
Answers
12
Questions
0
Helped
42117
Points
35
The reason that it launches the phone in the case you mention, WorkMobile, is because DataWedge acts just like keyboard input. It basically looks to the whole device like has just gotten data from the keypad. So, what happens when you're not in any program and you start pressing numbers? It pops up the phone application thinking you must want to call someone. So scanning in a numeric barcode does the same thing. If the barcode doesn't contain numerics then it wouldn't do that.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk, push-to-talk over WLAN software - 5 user license is FREE)
www.radicomm.com
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Feb 23, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
11925
Points
9
You need to be in an application first. For example, launch mobile Excel and make sure your cursor is in a cell. When you scan, it will enter into that cell. Just make sure the cursor is in the cell you are trying to get the info into before you scan (If it's not working, the app you're running may not be compatible with the scanning function, but I've never seen this).
Oddly enough, from what I've seen, if you just scan something without having an app launch, I've seen the MC70 default to the phone function and try to dial the number scanned.
Hello, I have a custom application but the scanner won't work with it. is there some way to enable the scanner to tell it to work. I have a quick scan sample app that works fine, but my custon app...
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Is there a way to turn scanner on and off in a motorola 9090g. It appears it is only triggered in a application. I am trying to use the bar code scanner in a web based application.
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. You can also install the application DataWedge provided by the manufacturer. The DataWedge aplication will activate the scanner and the decoded barcode is sent as usual keypad inut to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
5helpful
Hello, I am with Motorola and have a MC5590. The scanner function does not appear to be working. I have version 6.5. Do you have an instruction set that can test the functionality of the scanner? Thank...
Hello Glenn,
to test the scanner I would suggest to download and install the Datawedge application. It is an desktop installation. As you will connect your MC55 to the Desktop per Active Sync the application will be installed also to your MC55.
The DataWedge aplication will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, if you scan a barcode a pop-up window will come up. Or if another application is running it will send the input to the application.
1helpful
Hi all i am trying to use barcode scanner in Motorola MC55 Handheld Mobile Computer. i have installed data wedge from...
Hello, Datamatrix is 2D Symbology. Actually this MC55 is a model with 1D Laser Scan engine. The laser cant scan 2D barcodes, therefore he is not decoding the datamatrix barcode.
You would need an MC55 with an 2D Imager or with Camera to scan 2D Barcodes.
1helpful
I have third party software to initiate scanner functions on the Motorola but they do not work. In fact I cannot even scan without using the "Rapid Deployment Client" provided with the hardware.How do I...
DataWedge is an Application provided by Symbol/Motorola to enable the scanning module also for application without the driver. Scanned barcode is sent like an usual keyboard input.
There can be just one active application using the barcode scanner. If you are running DataWedge, you would need to stop it before starting any other application with built-in scanner drivers.
To stop DataWedge just click on the barcode icon in a right down corner and select - Disable DataWedge
6helpful
Scan bar code using motorola MC75
MC5590 - Can Not Scan All Bar Code
You would need to configure the MC55 for the specific barcodes and lengths, there are some defaults values preinstalled. You can change them in the settings of your Scan Application.
Motorola MC5590 is not able to scan barcode
download the datawedge file for the mc55. Its probably not loaded and configured. Once you have this file on the device and you need additional information please let me know
Here is the version 3.1.7
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12465&sliceId=&dialogID=162320658&stateId=1%200%20162316370
[email protected]
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
