I have a V100SG Vicks by KAZ humidifier. I have not used it in about 3 years and I have lost the instructions. Can you help? Do I pour the Vick's solution in the water? or on the top container? How long before I see steam coming out?
SOURCE: Vicks caporiser is spitting water instead of steam
Have you cleaned it recently? Sometimes that's an indicator that it needs to be cleaned.
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
SOURCE: Vicks V3100 Humidifier
http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=285ef863f85db2982e6f095560687917
SOURCE: Vaporizer Instructions
Try this: It should let you download a PDF of the instructions.
http://209.85.173.132/search?q=cache:pbhjzMo9E3sJ:www.kaz.com/kaz/support/manual/%3FProductManualAction%3DrenderProductManualById%26ProductManualId%3D5faaee9ab20669a0a26a9fb6e6bb99f8+Vicks+Vaporizer+instructions&cd=44&hl=en&ct=clnk&gl=us
SOURCE: Owners Manual for 2005 Vicks V5100N Humidifier
www.kaz.com/.../manual/?ProductManualAction=renderProductManualById&ProductManualId
here is the manual for you unit. if you have any moe questions please let me know
