Kelty TC 2.1 Baby Carrier Logo
Posted on Feb 26, 2009
Kelty TC 2.1 child carrier - Proper fitting
I have a Kelty TC 2.1 child carrier - I can't get it set up so I'm not leaning forward at the hips - the weight is all on my shoulders and makes it difficult to go any distance. Any suggestions?
2 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jul 01, 2009
SOURCE: the hip belt rides up
You need to adjust the torso length. The adjustment is directly behind the part that goes against your back.
Anonymous
  • Posted on Aug 18, 2010
SOURCE: i am looking for an instruction manual for the
http://www.kelty.com/pdf/Kids/ACFF38.pdf
What to expect after Hip Replacement?
You've been in pain for a while. It hurts to walk, sit down and get out of a chair, and even to simply lean over. In fact, your hip even hurtswhen you're just sitting or lying down. So you've decided to move forward with hip replacement surgery.
One reason people are hesitant to move forward with this surgery, as with most surgeries, is not knowing what to expect after you wake up from surgery.
To quell your worries, here's a breakdown of what you can expect to happen after your hip replacement surgery.
1) Recovery begins immediately
As soon as your surgeon completes the surgery, your recovery begins by walking the same day as surgery.
2) Physical therapy is your new hip's best friend
3) Getting active
Mar 14, 2019 • Medical
Have huge Kelty ridgeway tent, maybe 20 yrs old. Heavy metal poles labeled red, green, blue. Can’t find set up instructions. Help!
I believe I have the same Ridgeway tent - over 20 years old. Red-, Blue- and Green-labeled poles. Best setup will require at least 2 persons. Here is a quick guide to setup:
1. First, stake the tent floor down making sure it is taut.
2. Center poles are labeled with Blue dots. There are 3 separate poles that fit through the center channel - 1 straight pole with 'male' connectors on each end (this will be in the middle), and 2 poles with curved 'female' ends. The curved ends need to slip through the center loops (there's a 'hook' to hold the loop). The center upright poles consist of a bottom pole (which should have a cap on one end and an adjustable ring on the other) and a 2-piece snap pole (with grooves on one end). Make sure to slip the pole with the grooves through the adjust ring (this will allow adjusting the height of the center of the tent). There are also 2 strings at the center of the tent about a foot above the ground. Tie these strings around the upright center pole to ensure that the center upright pole doesn't separate too far from the tent.
3. Poles with Red dots are for the ends of the tent. There is a curved 2-piece snap pole that slips through the end channel. Then, you have a 3-piece straight snap pole that attaches to each side of the curved pole. The bottom end of the straight pole should be placed about a 1.5 feet from the bottom of the center pole (at about a 45-degree angle). The door ends are essentially 'leaning' outward from the center.
4. Poles with Green dots are for the extended door cover on the large door side. These are 2 snap poles with ends that fit through the grommet holes of the cover.
Photos of erected tent are attached.
We don't use our tent very often, but my son just took it camping and it was a breeze to set up. If you still have the plastic stakes, I would recommend replacing those with metal stakes, as the plastic stakes break easily. Also, you may need to find a rain fly that fits the tent.
I lost the instructions
I was able to locate the manual for this carrier on the Evenflo website. http://www.evenflo.com/on/demandware.static/-/Sites-evenflo-Library/default/dwd2a5aaf9/Instruction%20Manuals/EV%20Natural%20Fit%20Carrier-5763.pdf
Looks pretty straight forward. There are also videos on youtube of people demonstrating the different positions.
Hope this helps!
I purchased a used Kelty Redwing 2000ST backpack, and I noticed an area on the back (about 2 1/2 inches long) where the material has pulled apart from the seam on the left side. I would like to know if...
Kelty has a lifetime warranty on all of their backpacks For additional information concerning warranty, parts, or repairs please contact their warranty department at 1.866.349.7225 or preferably by email at [email protected]
How to collapse a kelty journey backpack carrier for a child
We just had this problem last week - it has to do with loosening the straps. Play around with them for a bit and try to loosen, this just loosen the bar so it can be pushed in.
The hip belt rides up
Back length adjustment on baby carrier
Take a look on Kelty's website by clicking the link below: http://www.kelty.com/kelty/instructions.php Good luck Ian
Top Kelty Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Kelty Baby Gear Expert? Answer questions, earn points and help others
