Galt Construction Vehicles Shaped Puzzle Logo
Posted on Mar 01, 2009
Galt puzzle 14 coloured blocks, cant put it
Galt Blue puzzle, 13 coloured blocks, cant put it together? Manage to get 12 in and then 13th doesnt fit?
  • Anonymous Mar 23, 2014
    PUZZLE Answer for JUMBLE
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1538
Points
Galt puzzle 14 coloured blocks, cant put it - puzblk1.gif The rest go in easily!!
Is there a way to solve the 13 piece puzzle ?? a starting point would be helpful
when doing picture puzzles ( jigsaws) the best place to start is the edge pieces ( those pieces with straight sides
corners will have 2 straight edges joined and the rest will be one side straight
then go for same colours or lines
Jun 24, 2015 • Puzzle Toys
8x + 10y=-14 -x+y=13
y=13-x, so 8x+130-10x=-14, so -2x+130=-14, so 2x=14+130 =144, so x=72 and y=13-72 =-59
Oct 23, 2014 • Toys
4helpful
2answers
How to solve a moon shaped 3d crystal puzzle
23 20 21 3 post 14 18 10 15 17 7 8 1 16 12 11 9 6 5 2 19 4 22 13 then 13 22 4 19 2 5 6 9 11 12 16 1 8 7 17 15 10 18 14 3 21 20 23. Good luck (especially telling 6 and 9 apart)
Jul 07, 2012 • Puzzle Toys
How to put a chad valley trampoline together
Hi I've just bought this and can't get the springs set up. Did you manage it x
Apr 07, 2012 • Grilling
4helpful
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
9helpful
2answers
I need help with puzzle 100
There are 28 PINS -- Count each PIN starting from left to right on each line. (1 -- 28)
Square ( 1) Join together Pin No's ( 1 -- 2 -- 6 -- 7 )
Square ( 2) Join together Pin No's ( 4 -- 12 -- 21 -- 27 )
Square ( 3) Join " " " ( 5 -- 9 -- 11 -- 15 )
Square ( 4) " " " " ( 3 -- 10 -- 13 -- 19 )
Square ( 5) " " " " ( 8 -- 16 -- 23 -- 28 )
Square ( 6) " " " " (14 -- 18-- 20 -- 25 )
Square ( 7) " " " " (17 -- 22 - 24 -- 26 )
GOOD LUCK.........
1helpful
2answers
Where is puzzle 120
http://www.wikicheats.com/index.php/Professor_Layton_and_the_Curious_Village_(DS)/Walkthrough#Puzzle_No._078
Go here for all puzzle walkthroughs
Puzzle No. 120 Tap the open manhole above from the Sewers below.
Get the Ball Out! 3: Slide the bottom-right blue block over to the right and drop that lower purple block in the slot with the hole. Now, drop the big yellow block down. Drop the top purple block down one and then reposition the top two blue blocks so they are touching end-to-end directly under the red ball. Raise the left green and the big yellow block up into the center. Slide the bottom-right-most blue block all the way to the left. Drop and slide the other right-hand-side blue block as far left as it can go now. Drop the green block on the right down and into the right-hand nook. Slide one of the top blue blocks to the far right along with the yellow block and the right-hand blue block on the bottom. Drop the red ball all the way down to the bottom row. Move the left-hand green block up into the ball's starting slot and slide the yellow block all the way to the left. Move the bottom-right blue block up and the small purple one that blocks the hole. Now simply put the red ball into the hole.
10helpful
3answers
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Problem with the vga cable
Put the connector infront of you and take biger size to top and smaller to down then count the pins like this-1=red,2= green,3 =blue(count the pins right hand side to left hand side),4=ground,5= blank,in lower row 6=red ground,7= green ground,8=blue ground,9,10,11=blank,12,15= in command section,13=horizantal synk,14= vertical synk.Hope this solution works otherwise i am always for help you.
Top Galt Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Galt Toy Expert? Answer questions, earn points and help others
