I'm looking for makita inverter generator G1700I parts.I bought it 4years ago and went to use it the other day but it didn't work having taking it apart the magnets are cracked and chipped inside.The company I bought it off have closed and now I need the parts to replace the magnetic drum inside any help would be grateful thank you
SOURCE: Magnet fell off one of the top speaker on my soundsticks
this just happened to me and i used two twisty ties for garbage bags to fix the problem.
thread them through the holes in the top speaker, the one that's loose. then simply pull it back into place. you'll hear a satisfying "click."
SOURCE: Colemen powermate Generator 6875w 5500
GENSET ALL PROBLEM FIXES - 2 PARTS
My answer:
Almost 90-95% of all the Genset problems found by the factory approved Genset Service Centers
are related to the fact that people don't read the OWNERS MANUAL first, and
just didn't put OIL in the Genset (or the right amount) - as they are shipped from the MFR
without OIL in the units to begin with!!!! (See esp #3 and Final Notes below as well)
And here I thought everybody KNEW THAT!!
I guess sometimes you just have to ask the most OBVIOUS ??'s first huh (dumb as " it " may sound)?
If you bought your Genset from other then a Home
Depot Store, and it's still under warranty - then you will have to
contact that outlet, and see what they have to say or hopefully can do
for you.
Esp all those Gensets that are Made in China and have flooded the USA
market in the last 10 years or so - no thanks to our representatives in
WASH DC that's for sure. It's a wonder this country even functions with
all this "inferior" Made in China JUNK that keeps prematurely failing
before it's normal time. Sad to say the least!
Some other obvious things to CHECK for that may be the cause of a NO
start condition even after adding proper gas & oil to the brand new
Genset:
1 - Some Genset gas tanks come with a gas cap "blocking insert" under
the gas cap that should be removed according to your manual if it
states this. (Read manual section on "First Time Starting")
2 - Is the gas tank shutoff valve FULLY OPEN? By the same token
(even
if the Genset is or isn't brand new) does it have an in-line fuel
filter anywhere in the gas line? If not then esp read #5. Always check
as well the AIR FILTER for proper cleanliness (if oiled type), or clean
appearance if it's a paper element type. Clean or replace as needed!
3 - Is the RUN SWITCH set to ON or RUN position (this is purely an
"Electrical ON-OFF Switch" usually a single-pole single-throw type btw,
and it can go bad with high usage)? Does it move freely from OFF to ON?
Is it working properly? Test it using a known good quality DVM
or OHM meter! It's contacts may have become tarnished just from sitting
around
too long? Esp where you have saltwater conditions in the surrounding
air! This switch actually & electronically is wired in REVERSE so
that when switched to the ON position the wired contacts are OPEN thus
letting the Ignition Coil fire for SPARK. When switched to the OFF
position the wired contacts are now CLOSED thus connecting (or
switching) the "Control Board" logic voltage signal (usually anywhere
from +3 to +12 VDC upon start-up) to GROUND - thus cutting the RUN
voltage to the Ignition Coil fire - as in SHUTDOWN. On some model
designs there also may be a separate IDLE CONTROL SWITCH and POWER
REGULATOR BOARD for better POWER LOAD self-regulation depending on
constant variable loads placed on the Genset as related to the
work-site demands. If there is NO VOLTAGE OUTPUT but yet good engine
RPM function - then I would look at this part first and then #8.
4 - Is the choke being set to the proper position with or without using Ether spray to the Carb?
5 - Does the Carb have a Yellow or Black wire coming off of the bottom
of the Float Bowl? This goes to the GAS CUT OFF SOLENOID mounted in the
Main Jet inside the Float Bowl. NEVER CUT THIS WIRE as some know-nothings have
suggested here and elsewhere in postings, as there are better ways to test the solenoid without doing
that! If equipped with one - This anti-dieseling solenoid has to work
properly or else flooding will occur with the gas shutoff valve OPEN.
6 - VERY IMPORTANT - Is the Carb Float stuck in the CLOSED position
not letting gas into the Main Jet? If the Genset is brand brand new and
truly has never been fired up even once and used, such as like that of
2-3 years or longer from actual date of purchase, then that Carb Float
may very well be stuck CLOSED. Worse yet - the Main Jet may be clogged
with MICRO DEBRIS coming down from the new gas tank - esp if there is
NO FUEL FILTER present in the fuel line. I've heard of this happening
more then just a few times myself. You might try
and TAP CAREFULLY on the bottom or side of the Float Bowl
with a hard rubber hammer first to try and see if you can dislodge the
stuck Float inside. If there is that colored WIRE (see #5 again) at the
bottom of the Float Bowl
on your model - DO NOT HIT THAT GAS SHUT-OFF SOLENOID WITH THE RUBBER
HAMMER - as you WILL damage it! If this dislodges the stuck Carb Float
to the point that the Genset now wants to run to some degree better
then before, but not fully 100% better and to spec - then you
definitely still have Carb Float and/or fuel delivery related issues,
and/or MICRO DEBRIS in the Carb Bowl or Main Jet inlet. If the Genset
begins to run great - as it should - and continues to do so -
then your NO FUEL or NO RUN problem is solved! I would still take the
Carb Bowl off and clean out the whole Assy there just as an added
precaution anyway as you just never know. When Gensets are truly needed
in an emergency condition you just don't want to RISK anything!! NEVER
FORCE ANYTHING EITHER!! It's possibly that you might have to loosen slightly,
and/or totally remove the
Float Bowl (usually 2 screws) to see if indeed any gas is getting
inside to the Float
at all. If gas comes out readily but still no gas is getting into the
Main Jet and intake then you purely have a DIRTY CARB issue and nothing
more!
If you're not smelling gas through the air filter box then you are FUEL
STARVED. ALSO - Many a brand new shipped Genset will have some kind of
NEW gas tank (usually metal gas tanks only) MICRO DEBRIS inside the
tank itself or even in the rubber gas line (I've heard of this problem before,
and seen this myself 100's of times with cheaper rubber hoses). That is
why an added in-line FUEL FILTER (if your Genset has none) is SO
important!! Usually a common $2-3 item at any auto parts store. Once
gas is added to the tank all this micro debris is set free to enter
into the CARB FLOAT BOWL, and that is where Carb problems will start -
even with a "brand new" never run before Genset!!
SOURCE: Generator is not working!
pramac has bought coleman powermate. to order parts call 1-800-445-1805. my guess is the printed curcuit boaed on the back of the gen head is bad if sparking the roter doen't fix it. i hav e had to change alot of these boards out.
SOURCE: Brand new Generator not working
pramac bought coleman powermate phone 1800-445-1805. try to spark roter if thats not it maybe printed curcuit board in the back of generator head
SOURCE: Zanussi IZ12 part identification
The part you refer to is called a pressure switch, as water enters the drum it forces air up the tube at the bottom of the switch whitch controls the amount of water the machine takes in depending on the wash cycle selected. As long as you put it back together properly it will work fine. They are factory set and can not be calibrated. (if faulty it must be replaced)
I have checked 4 sites that I use and none are coming up with that model number. If you want to recheck and give me another number I will try again if not Makita has a toll free number for tech support and they are really great at helping it is 1-800-4625482. Let me know and I will do what I can
