It says: Program memory is low. you must select one task...................the amount of program memory, if available.
(the dots means : I cannot see the rest of the message it's hidden behind the screen.
Convert some storage memory to program memory system control panel to adjust memory later.
You can email me @: [email protected]
I am looking forward to hearing for you
thank you
You can email me > [email protected]
thank you
Save the money question here...google your model XNA3550 and you can order it online....pretty psendy though...here's a link:
http://www.google.com/products?hl=en&safe=off&ei=ELW4SeS0MImMsAOt2YQ3&resnum=0&q=Dual+XNAV3550+memory+card&um=1&ie=UTF-8&ei=FLW4SYWALpKWsQPU07RH&sa=X&oi=product_result_group&resnum=4&ct=title
Email [email protected]
and/or call 1-866-429-1628
Their manual doesn't cover much and this does seem to be a fairly common problem. Have you tried upgrading the memory in the unit? The quickest way would be to contact DUAL during business hours.
Thank you,
Lee
You need to install another memory card with high capacity to solve this problem.
You can get the card from ebay
Click this link to direct to ebay
Your model supports only SD cards . You can get from any shop .
Reset the gps and check out.there is small hole under its side to reset.use paper clip to insert in the hole to reset.
Downloading and installing your map
(5)
Select your navigation device:
Before you disconnect
(6)
If you have a speed camera subscription, install your TomTom speed cameras.
Select your new map
(7) If you have more than one map installed on your device, select the new map. On your navigation device, tap Manage maps in the Preferences menu and then tap Switch map.
my gps model is dual navatlas xnav3550.
but i cant find reset hole to reset as you say.
pls tell me where is reset hole
thanks
where can i that memory card?
