SOURCE: I have a Stihl FS 80 that needs both crankshaft
try outdoorpowerequipment.com free pdf format manuals ? hope yhis helps doc
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
SOURCE: schematic diagram to repair a STIHL FS 45 trimmer
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
