Neovo AG 17" LCD Monitor Logo
kevin stoddart Posted on Aug 15, 2007
Neovo x17a monitor
Power input is ok led is on but have no picture can this be repaired?
Anonymous
Level 1:
  • Contributor 63 Answers
  • Posted on Aug 15, 2007
Anonymous
Contributor
Level 1:
Answers
63
Questions
Helped
28258
Points
65
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
2answers
Ag neovo
Change your power supply.
2answers
Driver for neovo F417 lcd screen windows 7
No drivers are necessary. If Monitor is seen as "Plug and Play monitor" is ok.
Neovo x17a starts up then screen goes blank. unit still powered. tried replacing caps in psu and inverter, but still the same
The problem can be the inverter transformers or lamps assembly.
You can look for number as printed on the transformers and go to www.lcdparts.net to look for pinout and resistance reading. Checking for bad lamps will be more difficult unless you have spare test lamps.
One thing you will have to remember is that the cap can look OK but it can have high ESR, you will need cap tester that can do the test.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Send me pictures if you need more help: [email protected]
The monitor won't go on after holding the power button
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
1helpful
2answers
My Neovo E-W22 monitor quit working. I have had it just under 2 years. It is as if it is getting no power. Any ideas?
Make sure the power connector is secure with your monitor and the adapter power light is on as green. If not working at all then just contact with AG Neovo as [email protected] for 3 yrs warranty repair. But you probably have to cover the one way shipping only.
7helpful
6answers
Screen goes black in half a second....
Call the service dept. in the above post. Tell them the model and serial number of your monitor and order a backlight inverter board(approx. $35 plus shipping). Open up the monitor and plug it in, should fix the problem. This problem could also be caused by one or more backlights(small flourescent tubes) being bad. I just fixed a Neovo F-417 display by replacing one of the backlight assemblys. I also just fixed a Neovo E-17DA monitor by replacing the inverter board.
2helpful
3answers
Screen is gone in half a second....
could be the lamps or the inverter board
Top Neovo Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
