Depending on the age it could be just some orings leaking or a connection that has come loose. Or it could be the boiler leaking. Not knowing the age it is had to know which. You should google "saeco repair" and have an authorized repair center take a look.
Screws:
#9 torqes under water tank
Two phillips in bean hopper
1 under bean hopper back side way down in hole
open door see two screws on outside leading edges.
Knob:
turn knob counter clock wise look up under righ leading edge of machine see the stem of the knob. There is a pin to push to release the stem.
Top should then lift off.
It ia factory refurbished and about 6 months old. How do I get the back off so I can look to see if a tube has come loose or something?
Thanks
Excellent...was able to spot a split in the water line where it connected under the water tank and fix it. Thank you so much!!!
