How do I replace the internal shock cord in my Marmot Taku tent poles? The cord is knotted just inside the final connecting sleeve rather than at the pole ends, so the connecting sleeve must be pulled out somehow without damaging it or the pole.
SOURCE: Need replacement poles for Cabin Tent
Do you have a Northwest outlet in your area? Otherwise you can get it from the manufacture.
SOURCE: I have stripped the thread in an extendable tent pole.
if you go to any good tool store or engineering store you can get what is known as helecoil insert.just tell them the inside diam of the pole.they will probably put it in for you if yuo take the pole along.hope this will help.regards barry.
SOURCE: Centre pole is failing to hold tent up in any real wind
TRY DRILLING A SMALL HOLE ON THE INNER POLE SLIGHTLY SMALLER THAN THE DIAMETER OF THE SCREW. U WILL WANT TO DRILL SMALL HOELS EVERY FEW INCHES(CM) SO THAT U WILL BE ABLE TO SET THE POLE AT VARIOUS HEIGHTS IN THE FUTURE.
SOURCE: The elastic cord of the tube poles of the rainfly
Those stretchy tent poles are at walmart, real cheap, Buy a couple and you will have a spare. If you want to fix the old one, I would try a couple solvents to loosen the glue, then remove the tip. Goo gone, or one of those to start, then move up to the mineral spirits, then the laquer thinner, If that doesn't do it, Nothing this side of fire will do it. Laq thinner is the strongest solvent available. Be carefull.
SOURCE: square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
