Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
Posted on Apr 02, 2009
Motorized brush bar not turning on Dyson Vacuum
Started as an intermitted motor issue not turning the brush bar on the bottom of the dyson ball when I pushed it forward and as I returned it to almost upright the brush would turn. Now when I start the vacuum I can not get the brush to turn at all. Great suction still from the handle and accessories but to vacuum carpet it does nothing.
  • 1 more comment
  • Anonymous Apr 22, 2009
    I too have the same problem. Have taken it apart, there isn't a belt fitted. Have spoken to dyson £65 to come and fix it.
  • Anonymous May 08, 2009
    I haven't looked at mine yet, I just noticed this problem for the first time today. I think it has to do with the wires or contacts that feed the brush bar motor. since they are past the funky swivel they seem to be creating an "open" at a certain angle. If I hold mine as close to vertical as possible while in use the brush bar always works. It's when the angle is less than say 75 degrees it cuts out. I will open mine up shortly!
  • Anonymous May 09, 2009
    Was experiencing the same issue after only two uses. Initially, the brush wouldn't turn at all...no matter what angle it was at. And then sometimes it would turn when it wasn't vertical. Really no rhyme or reason as to when it will spin and when it wont. Just luck out sometimes and then sometimes I don't. Yay for paying $400 for a vacuum that works great half the time.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
54595
Points
34
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
  • Anonymous May 03, 2015
    Thanks for this post! My Dyson had the same problem, and is now back to operational, thanks to your info. I soldered in a 3" wire to extend the length of the broken wire.
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
65473
Points
39
There are other ways the brush bar could stop working, So this will not fix everyones problems but as I posted before I had a feeling there was an open in the brush bar circuit. And since there is a pivot point I was almost positive that was my problem.
Today I opened up, two caps on the left side and found a broken wire, I really don't know how it worked at all, since it wasn't just partially broken it was completely broken.
[IMG]http://i471.photobucket.com/albums/rr74/NinjaRider08/Dyson_DC15.jpg[/IMG]
<a rel='nofollow' href="http://s471.photobucket.com/albums/rr74/NinjaRider08/?action=view&current=Dyson_DC15.jpg" target="_blank"><img src="http://i471.photobucket.com/albums/rr74/NinjaRider08/Dyson_DC15.jpg" border="0" alt="Photobucket"></a>
All in all it took about 15 minutes, for me but I'm an electronic engineer, now it works good as new
  • simon_l_peel Dec 12, 2010
    We were about to call a Dyson engineer for £80 when I read this post. I opened up my Dyson DC15 and sure enough there was a wire about to snap that had been causing the issue - thanks for saving me a lot of time and money! Simon
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
54004
Points
With our DC25 Animal machine, the brush quit turning after it got jammed while trying to vacuum something it didn't like. After waiting the required 60 minutes, as the solution in the book, the brush still did not start. I checked for blockages and cleaned both filters, emptied the canister, and it still would not turn the brushes. Everything else worked. I finally called the customer service line and she had me turn the machine on, lower the machine in the position to vacuum and then press the secret GREY button on the handle for five seconds and the brush motor will reset. I followed her instructions and sure enough the brushes started to turn. McGyver I am not, nor am I James Bond, so whoever printed this instruction manual needs to find another job. Before taking the machine apart to check the wires others are writing about here, try pressing the super secret problem solving grey button on your machine, next to on/off button, and your brushes may start turning again.
  • Anonymous Dec 13, 2012
    What model Dyson do you have? I have the DC 15 ball all floors. I don't see a grey reset button on mine. I have the same problem with my brushes being intermittent.
  • Patty Cake
    Patty Cake May 02, 2014
    did not work for me, after cleaning and taking apart, then trying this fix over and over it still will not reset.
Anonymous
Level 1:
  • Posted on Apr 26, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
54004
Points
I had exactly the same problem, took the lower handle cover off and found the orange wire had snapped inside. I ordered a new pair of wires from a local Dyson specialist for £4.25. The part is called Loom BB Over Current , part number 907280-03
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Nov 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
55622
Points
15
The issue with the plastic "female" ends of the bar appearing too large is due to the brush getting stopped by something (usually long carpet fibers or string you may accidentally run over). While most vacuums have a belt driven brush bar, which would allow the belt to slip when this happens (remember that burning rubber smell on your old vaccuum?) the Dyson uses a gear.
This allows the "male" metal ends to continue to turn when the bar is stopped, which will quickly **** out the "female" ends, since they are plastic.
If they were metal as well, the motor would burn up. In this case, the only solution is to replace the bar. Perhaps in newer models, Dyson will include a clutch that will allow the motor to slip when the bar gets stuck.
Hawk Wala
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Aug 08, 2011
Hawk Wala
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
62681
Points
52
This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver tx 15 to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers located on the right side of the vacuum (Photo 1). There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
motorized brush bar not turning on Dyson Vacuum - a88d5796-cdbb-4b92-8634-ac3f735f94b5.jpg
Anonymous
Level 1:
New Friend:
  • Posted on Jan 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
54004
Points
Thank you everyone for you help. I was able to read your post and comments and fix mine the exact same way. The problem that I noticed is the rubber gromment that they use does not give any play for the wires to slide back and forth. By the naked eye it looks like they are still together but with a small tug the wires seperate. I replaced the small gasket and fixed the wires and the machine works amazing.
Anonymous
Level 1:
New Friend:
  • Posted on Nov 14, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
54004
Points
Happened to me, too. From what I can see, the plastic female end of the endcap was worn too large from the metal male end that the brushbar fits into. Mine lasted about 2 years before this problem. I ordered a new brushbar and the problem is gone. Good luck.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
55186
Points
6
Has the belt snapped
JIM
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Feb 09, 2019
JIM
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
68187
Points
20
teachmhs
Level 1:
New Friend:
  • Posted on Feb 28, 2011
teachmhs
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
54004
Points
Was ready to buy new vacuum, your comments were the solution, yellow wire busted. I picked the ruber seal out and used ice pick to expand hole; made it easy to get wire through. I spiced wire and used electrical tape. I applied a little water on plug as lubricant.
Anonymous
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on Jul 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
54004
Points
Mr. James Dyson is a genious but should have continued the yellow/orange wire shroud right through the ball mechanism. Solution # 3 was spot on. Thanks Mike.
megan carlson
Level 1:
New Friend:
  • Posted on Aug 06, 2015
megan carlson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
54004
Points
Had same problem. yellow wire was broken, blue had bare wire showing. added 3 inches of wire, works again. i messed with spinning brush area looking for these 2 wires but they are in by the ball pivot area where you can remove 2 screws to get to them
Tonya Sohm
Level 1:
New Friend:
  • Posted on Jul 31, 2015
Tonya Sohm
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
54365
Points
5
Anyone know what size wire? I'm very mechanically inclined but very broke, with bad allergies, and really need to get floors cleaned so any help is appreciated.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Posted on Jul 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
58454
Points
Turbobar brush not working on DC 15
1helpful
The brush quits running, however, the machine still runs like the brush is rotating. Then the brush all of a sudden kicks in and runs then stops.
Hi Janice, it's Jack at Dyson.
DC25 has two motors - one is housed within the Ball and generates the suction, and the second one is mounted within the cleaner head and powers the rotating brush bar. It's possible for the suction motor to continue to run when the brush bar motor is switched off.
Like most Dyson vacuums, DC25's brush bar motor will shut off for protection if something is jamming it. If you're finding your machine's brush bar is running intermittently, it's a good idea to check the cleaner head for any obstructions, and to remove any threads or hair from around the brush bar. Our video guide shows you how:
If you'd like any further guidance after you've given this a try, our experts are standing by to help. You can reach them directly by calling the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Dc dyson 24 free repair maule
About 1,100 results (0.84 seconds) Search Results
    Dyson DC24 - Resetting the brush bar (Official Dyson video ...
    ? 1:55
    https://www.youtube.com/watch?v=akGLQ7UbctY
    Sep 29, 2011 - Uploaded by AskDyson
    DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
    How to fix your Dyson Vacuum Cleaner when it loses ...
    ? 7:45
    https://www.youtube.com/watch?v=0vd3ldLXgI4
    Apr 16, 2013 - Uploaded by Chuck Fresh
    How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
    [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
2answers
How do I get the brush to spin on a Dyson DC 24. I have thoroughly cleaned everything and pressed the reset button.
Hi , if i am correct the brush bar is driven by a small electric motor inside the brush bar. It sounds as if the motor has gone or the small printed circuit board has a fault. You will have to get it checked.
Why want beater bar turn on Dyson DC17?
There are a few things it could be. Pull the handle back into the vacuuming position and turn the brush bar switch on and off while listening to see if you can hear the brush bar motor turn off and on. If you can hear the brush bar motor running it may need a new belt and/or the brush bar may be seized up.
There is a switch by the main power switch that provides power to run the brush bar motor. There is a micro switch down in the motor area that closes the circuit to the brush bar motor when you pull the handle back. Check electrical connections and all of the above parts to determine which one or one's may be defective.
1helpful
Dyson DC27 brush drum fails to rotate. Belt is fine.
Dc27 has a motor to spin the brush. It might be the brush bar motor or the power switch to the brush bar motor.
Ball makes a clicking sound and brush isn't turning
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.Turn it over and wipe all the black residue off the bottom of it.------ Either the brush is getting clogged and blocked by dirt, hairs etc etc and that needs to be cleaned or the brush bar motor is got faulty and needs to be replaced.------- You can yourself replace this motor,m if its not running.------- To get instructions to disassemble the vacuum and replace the motor, click this link below :--- http://howtobyme.blogspot.com/2011/08/brush-not-turning-on-dyson-ball-dc24.html----------- This will-help.Thanks.Helpmech.
8helpful
2answers
We have a Dyson ball vacum the brush stopped working it is no longer turning
There is a known issue with the DC24 brushbar motors. First thing to do is try the reset button. That is located on the left of the brush bar unit as you look at the machine. It is red. Press it and see if the brush bar works when the machine is reclined then. If it doesn't, you most likely need a brushbar motor. You can get one from here: Dyson DC24 brushbar motor.
19helpful
On my dyson DC24 the beater bar attachment is not working.
Hi its Darran at Dyson.
You may to simply re-set the brush bar. The cleaner head will automatically switch the brush bar off to protect the motor should the brush bar become obstructed. To re-set this, switch the machine off, stand it upright and locate the red re-set switch on the side of the cleaner head. Push this re-set switch in as far as you can and then switch the machine back on. Once lowered into the vacuuming position, the brush bar should start turning.
If this doesnt resolve the issue, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service.
2answers
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
