Ricoh Aficio 450 Copier Logo
Posted on Sep 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Network I am not able to network machine can not find display to configure
Anonymous
Level 2:
  • Expert 163 Answers
  • Posted on Sep 13, 2007
Anonymous
Expert
Level 2:
Answers
163
Questions
Helped
88489
Points
221
Plez you check the printer board of your copier
How do I retrieve info from 3210/3220 work centre fax stored in memory
We encourage you to use our knowledgebase MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year! We can solve your problem!
Email [email protected] for more info.
Solutions for : How To Print Reports Solution : Print Reports NOTE: Some report options may not be available depending on the product configuration.
  1. Press the [Menu] button on the Control Panel until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [OK] button.
  3. Press the [Left] or [Right] arrow button until "Reports" is displayed.
  4. Press the [OK] button.
  5. Press the [Left] or [Right] arrow button until the required report is displayed. The following options are available:
    • [Configuration] - This report lists the status of the user-selectable options. Print this list to confirm changes after modifying settings.
    • [Address Book] - This report lists all of the fax numbers and e-mail addresses currently stored in the machine's memory.
    • [Send Report] - This report lists the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results for a particular fax job.
    • [Sent Report] - This report lists information about the faxes and e-mails that have recently been sent. The machine can be configured to automatically print this report every 50 communications.
    • [Fax RCV Report] - This report lists information about the faxes that have recently been received.
    • [Schedule Jobs] - This report lists the documents currently stored for delayed faxing, including the starting time and type of each operation.
    • [Junk Fax Report] - This report lists the fax numbers specified as "junk fax" numbers.
    • [Network Info.] - This report lists information about the machine's network connection and configuration.
    • [Network Auth List] - This list shows authorized users who are allowed to use the e-mail function.
  6. Press the [OK] button. "Print?" will be displayed.
  7. Press the [Left] or [Right] arrow button until "Yes" is displayed.
  8. Press the [OK] button to print the selected report.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=301,E=0000000000016129653,K=272,Sxi=4,Case=obj(2601)
tip
Printer IP Address Lookup
<span></span><b>Need assistance in looking up for your printer's IP Address?</b><br /><br /> Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it. <br /> <br /> 1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer. <br /> <br />2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following. <br /> <ul> <li>Start -&gt; Printers and Faxes, or Start -&gt; Control Panel -&gt; Printers and Faxes <li>Right-click the printer name, and left-click Properties <li>Click the Ports tab, and widen the first column which displays IP address of the printers </li></ul> 3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses. <br /> <br /> 4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -&gt; [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer. <br /> <br /> 5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
How to print a configuration page on a m20i
We encourage you to use our knowledgebase, MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year!
Solution : Print a Connection Page (Network Connectivity Report / Configuration Page) NOTE: Print the Connection Page to locate the TCP/IP Address for the WorkCentre.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up or [Down] arrow button until 'Reports' is selected, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Connect Page' is displayed, and then press the [Enter] button to print the report.
  4. Press the [Stop] button to return to the Standby mode.
http://www.support.xerox.com/support/workcentre-m20-m20i/support/enus.html
2answers
Where do i find the ip address for my lexmark z705 printer
This may help.
How do I find IP address of a network printer?
  • Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes
  • Right-click the printer name, and left-click Properties
  • Click the Ports tab, and widen the first column which displays IP address of the printers
4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -> [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer.
Thank you for choosing FixYa! have a good one!
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
13helpful
How to hard reset a 1312nfi
This reset will change user and network settings Before performing this reset it would be advisable to print some information pages to retain any settings that you might want to restore.
Configuration Page
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Configuration report, press OK.
Menu Structure
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Menu Structure, press OK.
Network Report
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Network Report, press OK.
After printing these reports it will be safe to perform an NVRAM initialization to hard reset the product. Follow these steps.
1. Turn the machine off.
2. Press and hold the right arrow and cancel (x button) while turning the machine on.
3. Release both buttons when Permanent storage init. is displayed.
Once finished resetting the machine will return to Ready.
1helpful
I want to connect my SCX 4500w to a new network (wireless). when i try to use a web page to configure the printer settings it doesn't response... I check the IP and write in in my Internet Explorer,...
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
4helpful
2answers
Configuration error
hello ,
when i start my sony ericsson k 550i cyber shot a message is displayed on the screen that, "configuration error. please contact your network operator or service centre.
1helpful
Currently working on XEROX WorkCentre Pro 55. Want to scan documents to my computer from newwork printer. What do I need to set up in order to utilize this feature. I tried scanning to a programed user...
> Support & Drivers > WorkCentre Pro 55 Support > Search Results Solution: Set up Network Scanning Using Server Message Block (SMB) Filing With CentreWare Network Scanning Software v 5.5x bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Prerequisites:
  • The printer must be connected to the network.
  • The IP Address of the printer is required, and the HTTP option must be enabled on the printer. If you do not know the IP Address, or whether HTTP is enabled, print a Configuration Report. See the Related Items below for additional information. If you do not have this information or the printer is not configured correctly, contact your System Administrator for assistance.
  • A user account for the scanner to login to the scan server must be created (account needs full control access rights). The user needs to be a local user on the workstation and not a domain user.
    NOTE: SMB uses local rights and not domain rights. Record the username and password for future use.
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
  • CentreWare 5.5x must be installed on a Microsoft Windows server or workstation on the network.
From the workstation or server where CentreWare is installed:
  1. Click on [Start], point to [Programs], select [Xerox CentreWare], and then select [Add Network Scanner]. The Add Network Scanner Wizard window will be displayed.
  2. Click on the [Enable a new Xerox System Scanner for network scanning and associate it with a scan server] radio button, and then click [Next].
  3. Select [Specific IP Address] from the Find Devices pull-down menu and continue with step 4, or select [Specific TCP/IP Hostname] and skip to step 5.
  4. If Specific IP Address is selected, an IP Address field will be displayed. Enter the IP Address of the printer in the field, click [Next], and then skip to step 7.
  5. If Specific TCP/IP Hostname is selected, a Hostname field will be displayed. Enter the printer’s TCP/IP hostname in the field, and then click [Next].
    NOTE: Select Specific TCP/IP Hostname if the Printer is using DHCP to resolve the IP Address and has a Hostname assigned.
  6. If the printer has been configured for Scan to File, a window will be displayed with a 'This device has already been configured for network scanning. Continuing will overwrite its current configuration. Do you want to continue?' message. Click on [Yes].
  7. The Enter Password window will be displayed. Enter your system password in the field provided, and then click [OK]. The Server Type (Filing Protocol) window will be displayed.
    NOTE: The initial system password at machine install is 1111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  8. From the Server Type (Filing Protocol) pull-down menu, select [Windows (SMB)].
  9. Click on the [Browse] button located below the Location (\\Server\ShareName\Path) field. The Choose Location – Windows (SMB) window will be displayed.
  10. Browse to the server and then to the Scan folder where the CentreWare scanning folders will be installed, and click [OK]. The Location field will be displayed with the scan server name and the path to the shared scan folder.
  11. Click [Next]. The Xerox System Login Name window will be displayed.
  12. Enter the scan user name and password (this is the user account the printer will use to login to the server share) in the fields provided, and then click [Next]. The Distribution Server window will be displayed.
  13. Do not make any changes. Click [Next].
  14. Click on [Manage User Templates]. The Manage User Templates window will be displayed.
  15. Click on [Modify Template List] to begin selecting template users for this scan server installation. The Modify Template List window will be displayed.
  16. Make a selection from the list of Users and Groups, and then click on [Add] to create a scan folder and template for the selected user or all members of a selected group. If necessary, repeat this step to add additional users or groups.
  17. When you have finished, click [OK] twice. The Finish window will be displayed.
  18. Click on [Finish] to upload the scan settings to the printer. The Add Network Scanner Wizard window will close when the settings have been uploaded.
6helpful
3answers
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
