There's several home remedies you can try:
Try 50% "White Vinegar", 50% Hot Water or
2 Denture tablets in warm water over night or
Baking soda in warm water.
These remove the alkaline, minerals, and nitrates that build up on the surface.
There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
I have the same problem. Noticed it was in two different pots. The comment number one must be correct because I only use VERY high alkaline water to boil my foods. I had a feeling it was my water. So interesting! I will clean it w white vinegar and see if the smell goes away. SAME weird chemical smell- turns your stomach.
Professional chefs face this problem many times over with their stainless steel wares. Fill the coffee pot with water. Add a tbs of bleach. Let set for 2 hours. See if that helps. If it doesn't, please let me know.
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Can it be fixed
