I bought replacement gas lines for my homelite bvm 160 gas leaf blower but now don't remember how they go to the gas tank. Any help will really be appreciated.
SOURCE: Homelite leafa Blower Model 08010B
They also provided the address of this parts supplier:
Gardner
Email Address:
[email protected]
Address:
3641 Interchange Road
Columbis OH 42302
614-456-4000
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
SOURCE: homelite Backpacker II leaf blower start fine then
have you checked air filter? the carb may need adjusting. locate the adjustment screw(s) , screw them all the way in then back out 1-1/2 turns. try to start the engine. then let me know what happens.
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
