SOURCE: processor
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
make sure your cpu has a 800mhz fsb
SOURCE: I want to upgrade my
Your Motherboard will support:
2 x 240-pin DIMM's (4GB Max)
Unbuffered
non-ECC
667/533/400 MHz DDR2
You should be pretty safe with any main brand name of memory from your local computer shop.
Below is a list of ASUS TESTED and Qualifed Vendor RAM.
SOURCE: does the motherboard supports intel
You can use duel core .
If you need more information, reply me soon.
Thanks
SOURCE: hello, i got maximus formula
This is your board by the numbers you supplied:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131199
You have Via P4M900 and VT8237 chipsets and Realtek ALC662(sound)
This is Asus's link for your board:
http://www.asus.com/Motherboards/Intel_Socket_775/P5VD2VM_SE/#download
It's supported to Windows Vista so, it may or may not work with Windows 7.
You can try your sound here, if necessary:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
and, this is Via's link:
http://www.via.com.tw/en/support/drivers.jsp
It appears your board has the support for Windows 7, if that is what you are running so these should be all you need. Let me know if I can help you further.
Dave
SOURCE: i have a ASUS P5VD2-MX SE Motherboard, does it support e5700 2m cache 3.o ghz
Try this link and go to 2:15 for the CPU's it supports http://www.cizgi.com.tr/resource/vfiles/cizgi/pms_file/134/p5vd2mxse_en.pdf
