SOURCE: Describe your Jura Capresso Impressa Z5 Espresso
will start by itself after it was shutoff for after
7-12 hours suddenly ? Why
SOURCE: jura capressa imprezzo z5 coffee machine, did not
return to service centre this one's a *****
SOURCE: Jura z5 after filling system said coffee ready
Someone online sells a special screwdriver head used to open the Z5. With it, it's possible to take the machine apart, clean up the coffee ground dust that gums up the moving parts. You can giggle sensor switches that get stuck. The water lines will need decalcifying eventually, even if you use the the Clearyl water filter cartridges. If you're not up to taking machines apart, sell me your broken Z5: [email protected]
SOURCE: How do I fix our
Press the button to the right of the function wheel that should be lit, this will then purge air from the water pipes and fill the boilers, the unit should then operate as normal.
SOURCE: Jura-Capresso Impressa Z5 - left coffee spout is
I had similar problem, Jura told to open a paper clip and push it up into the four holes on each spout. This worked the first time I had the problem. But now have one side not flowing again and the clip is not helping.
