They are security screws to stop you take it apart because of the HUGE coil spring inside it. Make sure you are wearing full PPE, gloves, eye protection and full face shield, with neck area and arms covered. It is likely to come at you as the halves split.
Auto Reel with hose (40m) · Premium hose, tough and durable · A powerful spring automatically rewinds the hose without any , tangles or effort · Wall ...
notify hozelock for replacement even if discontinued usually have parts available for replacement or if out of stock an aftermarket part plus most guns are a threaded to accept a hose
To restring the Hills Everyday 37 rotary clothesline FD88010 you are going to need a couple of tools which include a small screw driver and a set of cutters to cut the new line cord.
You will also need to order a pack of line, which for this unit would need to be the 70m pack from Hills. Here is a link to the line pack you would need.
Hills line clips could be something that you may also need in the restring process as these do tend to break on the older models of this unit. Below is a link to the Hills line clips that fit the Hills Everyday 37 FD88010 model.
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Simon from Hozelock : we need a bit more detail to help you if you want to make contact at [email protected] you'll find our team armed to the teeth with info !
This is a link to a downloadable PDF file on our website , hope it helps http://www.hozelock.com/uploads/pdf/instructions/watering instructions/33714-002 2N1 REEL.pdf you can also get help from us on Facebook or at [email protected]
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
