Hello cherylsacket,
Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
There are may possibilities, but these are some of the basic things to check.
Could someone have turned the color down?
You can go to the setup menu and "Reset" the player to the factory settings.
Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
Are the cables in good condition?
No breaks, loose connectors, they weren't smashed under a piece of furniture?
Have you tried a different set of cables?
Does the same thing happen?
Did you "Reset" the DVD player?
Maybe the DVD player is bad?
Does it work OK, or is it black and white too?
Maybe the connectors on the TV are bad?
Is there a custom setting on the TV for that connection?
On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
Best wishes,
-Greg-
