Radio controlled atomic clock was running 15 minutes behind. I replaced with new battery, pushed PT (Pacific Time) then nothing, nada, zilch. Pressed the reset button - it moved to 12:00, then nothing. Took battery out, put it back in - pressed PT again...still waiting. Any idea on how long it takes the radio controller to sync with the clock?
Please dont forget to vote this answer was helpful.
Many thanks
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
I'd say you have a lemon.
Manual:
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
For warranty work, technical support, or information contact:
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail
(warranty work)
(information on other products)
Website
http://www.lacrossetechnology.com/
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail:
[email protected] (warranty work)
[email protected] (information on other products)
same
No this is not the problem I had with my radio!!!! this is a clock
resetting Sharp Atomic Clock model SPC364
How many battery compartments are there and location of these on sioscan atomic clock model 86722
