The small shock is broke need a new one and where to get it
SOURCE: dropped camera and what broke was the rim on the very outside
You can contact Tamron directly: parts department: 631-858-8446
or via email: [email protected]
SOURCE: The bolt on the right front control arm that holds
I had the same problem with the shock mount. I used a cut off tool to remove the damaged stud then drilled out the riveted portion of the stud with a 5/8 inch drill. I purchsaed the 5/8 inch grade 8 bolt and nut from Tractor Supply. I welded the head of the bolt on the outside of the control arm with a mig welder. The 3 inch bolt length is perfect as far as the bolt shoulder ends just inside of the shock bushing.
