I have just given my explanation but not the BWE40 number. The machine was unplugged from the extension reel and now connected to the mains. The humming noise is constant and the BWE40 stays at 18 degrees. Thank you. [email protected]
SOURCE: Baumatic BW18 wine cooler; at
the soft humming your hearing could possibly be the compressor stalling.. this can come from a lack or freon. Now this is the first thing you should check as its one of the most common issues in all refrigerant systems.. to do this there is a check port that you connect a guage too and it will give the freon pressure. More than likely you will find it very low and needs re gassing.. before having it regassed I'd suggest that you have it checked for leaks as well ,, (it ran out of freon rather quickly no ??) have a technician come in and check these as he will have all the right tools and stuff needed for for the checking of gas pressure, the dye to check for leaks as well as the freon to regas it.. and if needed the solder to fix any leaks..
