the wii remote probably isnt conected... go to your wii device open the little tab to where the sd card should be. then open your wii remote and you should see a reset button on both of them (a red button) hold them both down at the same time... it syncs them also you may need to charge the wii remote
It should be able to connect via wireless. Simply switch on your Wii console, insert the disc and Cyberbike will
connect via wireless access, just follow the simple instructions and
you're off.
Hello Tatyana, You mostly need to steer and use the pedals. Depending on the game you play you may have to use some of the buttons - for example, in the Cyberbike original game you can use the a button for jumping over obstacles. You can also use the break to slow you down.
Please note that we do not monitor this forum regularly you can ask us questions directly at [email protected]
Hello, Yes, there is a manual, it can be downloaded at www.cyberbike-thegame.com click on the support section. It is likely that you have a defective handlebar if the Gamecube controller is not an option. If it is the case, we will send you free of charge a replacement. Best way to proceed is to send us an e-mail at [email protected]
take the cover off the back of the remote you will see sync button go to the game and open the litter door in front and push the sync button at the same time'
Look into http://www.fixya.com/support/t7615389-get. It'll work definely well with you Cyberbike paddling as speed control as well! Oh a word of warning, it's very very tiring to bicycle with 'Mario Kart' - an 'extreme excercise' NOT Recommend for old forks or 'light hearted' person!!!
PS. Wants more, the Cyberbike also supports 'Need for speed - Undercover' & 'Donkey Kong' !!!
Have fun...! As I'm cycling everyday with my Cyberbike Kart...
With some searching found english manual at http://www.cyberbike.be/sitemapENG_test.html
have to scroll down to support section. Then in the PDF section 4b has section to restore manufacturer's calibration. This worked for us.
