Http://www.amazon.com/Plugable-Adapter-firmware-backwards-compatibility/dp/B008ZGKWQI/ref=pd_sim_sbs_pc_2?ie=UTF8&refRID=1D72KVZ5HVA2JV88RXAV
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
I have the 80GB WD passport and it suddenly stopped working one day. The unit lights up but nothing else. Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in. I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine. Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone. They're just not sturdy enough or well designed.
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
SOURCE: How to recover data from a seemingly dead/non-functional USB flash drive
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
SOURCE: Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
